you can not use the 16 vlave ecm on your 8 valve harness or engine, put the 8 valve engine in, put your cut down wiring harness on the engine withan 8 valve ecm and relays, attach the wire to the points that it tells you to, like battery, ignition, fuel pump, the yellow wire on the back of the speedo (vss) those are just a few that I can think of maybe one or two more but thats it, cut the wires you need off of the 16 valve harness and hook them up to the 8 valve harness like the fuel pump and the vss,the others you could just hook them up in tandem. not that hard there are plenty of online manuals.
