zuketoy fromt axle finished
  • 1186 Views
Offline wezzlegod
  • 227
  • under construction crowler
« on: February 09, 2008, 05:44:36 PM »
ok i got some pix of the front axle. i finally got it finished. it took more time than i was expecting. lots of trial and error. hears the scoop toyota with 5.29s and lockright . im using QA1 14" 175 coil springs. i was going to do something different to center the axle but it would of taken too long and cost more money so i did it simple. i made mounts to hard mount the coil springs to both the axle ans the frame. ok hears the pix.
black 89 sidekick toyota 22re L52 5speed trans w/ duel t cases. toyota axles w/coil springs 4 link double triangle 3 link front, 5.29 r&p, lockers ,35x12.5 tires, rock rails ,custom plate steal bumpers, killer xm sounds ext ext ext
Offline wezzlegod
  • 227
Re: zuketoy fromt axle finished
« Reply #1 on: February 09, 2008, 05:45:55 PM »
more
Offline chet
  • 556
  • Zuki time!
« Reply #2 on: February 09, 2008, 08:48:13 PM »
nice work! Sorry to tell you though but you will get horrible bump steer with the short pan hard like that. it should extend all the way to the pass side and parrallel with the drag link
Offline wezzlegod
  • 227
« Reply #3 on: February 10, 2008, 09:25:57 PM »
ok drag link is from the steering box to the axle ??? ??? when the truck is on the ground the pan hard is level i thought that would work. oh well if it doesn't work ill have to rework it. anyone have feedback and some pix of their axle swap close up will help me.
