Need major help with carb quick
axelnut1
7
March 16, 2008, 02:21:30 PM »
Running a stock 1.3 in a 1988 Samurai. Everything was fine until earlier today. I was driving at 45mph and stopped at a stop light the carb decided not to idle down and then went up to about 6000 rpm. I shut the key off and tried to start it again and it went up to about 6000 rpm again before I could shut the key off. Does anybody have any ideas? I really need this fixed so I can get to work. Thanks in advance. Also, this was running perfect before this happened.
Last Edit: March 16, 2008, 02:25:20 PM by axelnut1
Gary_Hill
288
Re: Need major help with carb quick
March 16, 2008, 02:44:10 PM »
You have a bad throttle cable...probable at the hole where it goes thru the firewall. Should be easy to see if that is the problem.
ROSS
1412
WHY TAKE A PICTURE WHEN YOU CAN DRIVE OVER IT
March 16, 2008, 05:54:21 PM »
gary is wise OLD man . sounds like throttle cable
87 SAMI 1600 FUEL INJ. , TORQUER CAM, 6.5 TO 1T-CASE, 5"SPRINGS SHACKLE REVERSE ,2 BODY LIFT, LOCK-RITES FRONT W/ HEAVY-DUTY AXLES & ARB'S REAR BFG 31 X10.50 X 16", EXO SKELLETON,
RHodge
523
Reply #3 on:
March 16, 2008, 07:58:42 PM »
I had a stock carb do that, was out wheeling climbed a hill when I got to the top
RED LINE
I messed around with it for awhile but never figured it out just put a weber on it
but I third the cable, good place to start
Gary_Hill
288
Reply #4 on:
March 16, 2008, 11:49:55 PM »
The cable will be frayed on the inside of the firewall if I am correct...let us know what you find....Gary
