Need Help!
  • 1160 Views
Offline ldodge92
  • 107
Need Help!
« on: August 26, 2010, 07:10:42 PM »
Just replaced the front diff. Got axels back in and everything bolted up. Looked good. But when i tried to move, it rolled about 6 in and stopped. feels like something is catching in the diff.
My new addiction
Re: Need Help!
« Reply #1 on: August 26, 2010, 09:35:48 PM »
What are you driving? Did you put in different gears?
Offline ldodge92
  • 107
Re: Need Help!
« Reply #2 on: August 27, 2010, 03:09:43 AM »
Its a 90 sidekick 5 speed. Got the diff at a junkyard. Came out of a 5 speed tracker
My new addiction
Re: Need Help!
« Reply #3 on: August 27, 2010, 09:44:30 AM »
Did you pull the axles and swap the 3rd or the whole axle?
and did you keep the axles in their correct sides? they are different
in length.
Offline ldodge92
  • 107
Re: Need Help!
« Reply #4 on: August 27, 2010, 09:55:38 AM »
Just pulled them and swapped the 3rd. The axels never moved. Gonna go home, pull it, and open it up.
My new addiction
Re: Need Help!
« Reply #5 on: August 27, 2010, 06:06:37 PM »
Ya, you might have to, did you check for broken or missing teeth
on the gears when you pulled it??? Hope you have a warranty if
it's a broken unit
