Need Engine Help!!!!
  • 1246 Views
Offline Stinger
  • 15
« on: October 15, 2006, 03:41:21 PM »
Having problems with my 88 Sami 1.3l.
When you first start it up it runs fine, idles great, revs up nicely.
Once the engine warms up I have no power. It will idle irractically and stall when given gas.
So far I have replaced the accelerator pump, plugs, wires, cap , rotor, ignition coil, retimed the engine, reset all the valve clearances. Still nothing seems to help. Please let me know any ideas you may have on the problem.   Thanks
Rahn
Re: Need Engine Help!!!!
« Reply #1 on: March 11, 2007, 01:11:30 PM »
Did you figure out your problem? I am having something similar.
Tony
Offline Mike71
  • 1449
« Reply #2 on: March 11, 2007, 02:10:25 PM »
i had the same problem did the same things you did and it was the cat for me. i checked by dropping the exh at the manifold and running it problem didnt persist so i hollowed out the cat.
btw itl be very loud if you test it that way  >:D like nascar loud lol
623hp kb cobra sold! 100hp kick new DD :P
zydecobrett
« Reply #3 on: March 11, 2007, 03:43:00 PM »
Mine was dieing and the idle became too low. It was one of the vacuum hoses on the manifold . It was kinked and hence closing off. It was delivering vacuum. I put a piece of welding wire on it to hold it up so it could colapse. I reaaly should go spend the $.10 for a new piece of vacuum hose though. Fixed.
