Winches
  • 31 Replies
  • 6726 Views
Offline Mythose
  • 361
Re: Winches
« Reply #30 on: May 18, 2005, 02:45:18 AM »
LEVERAGE its all about leverage!
lol and so manny things are.
Offline cocobeachtracker
  • 43
  • 2006 Grand Vitara Luxury
Re: Winches
« Reply #31 on: May 18, 2005, 03:10:31 AM »
I have a Harbor Freight winch.  8000 lbs and costs under $300 on sale.  It looks just like a Mile Marker 8000.  I have only had to use it once to pull the tracker out of a high side(all four wheels off the ground), but I used it about twenty times to pull down oak trees after the hurricanes. One tree was a little too big and picked the tracker front wheels off of the ground.  I also put a harbor freight 2000lb winch on the rear(it was only $49).  I figure I can pull about a hundred pounds max with my body, so 2000lbs is a lot better.  Also good for pulling something on a trailer.  I fabbed up my own bumpers and winch mounts and everything is welded.  The winches themselves are through bolted and then tack welded to discourage theft.
Mike
2006 Grand Vitara Luxury, Trailer hitch, dynamat
