My patented revolutionary suspension design!
  • 36 Replies
  • 6641 Views
Offline windahdah
  • 20
  • Sidekick JX ROCKS
« on: July 09, 2009, 11:59:04 AM »
OK guys I'm going to spring something on all of you that has not been seen nor heard of yet in the world of suspensions.
Back in February I was granted a "provisional patent" for a totally new type of vehicle suspension.  Termed the "VX" suspension it offers numerous advantages over any other type of suspension, and my Sidekick was the inspiration for inventing it.
Basically I wrestled in my mind for several years going "why CAN'T an independent suspension have as much or more travel than a solid axle?".  This led me through several iterations of my concept until I arrived at the last one, for which I've applied for the patent.  I'm attaching the patent application which has a bunch of legalese but just FFWD through that and get to the admittedly lame drawings I've done.  I think you'll get the idea.
I believe that with enough careful packaging my design could approach 30" of travel in a Sidekick, the room in the chassis the only limiting factor.  This is with a fully independent design mind you!
Now the BIG news?  In "stumbling" upon this design I realized that, happily, I had just invented a suspension that has NO camber change and NO wheel scrub throughout the wheel's travel!  Eliminating those two bugaboo's has been regarded as the "holy grail" of suspension designs.  With further development of the steering system (traditional tie-rods won't work) I also have invented a suspension that has NO bump-steer or deflection steer.  The wheels quite simply move up and down in a perfect plane!  In essence the VX suspension approaches the theoretical ideal.
In order to make this suspension go I'll need to use "slip-yoke" style telescoping half-shafts on either side of the diffs.  Similarly a slip-yoke design would be necessary for the steering to work as well but neither of those things is earth-shattering...Live axles use a slip-yoke driveshaft with regularity, I'm just doing the same thing on the half-shafts.
I'm currently developing the suspension prototype in an RC car format, 2wd only and only the front suspension.  Basically I'm doing the minimum to satisfy the requirements of the US patent office.
Any feedback/advice from you guys would be great.  If any of you fabricator guys out there have any interest in developing this suspension with me I'm more than willing to grant exclusive rights to the Zuki market for nothing other than your time and effort.
So in a nutshell here's what I believe the VX suspension can achieve:
1) Up to or more than 40" of travel given enough chassis room, 20-30" for most production cars/trucks.
2)  Full independence with low un-sprung mass.
3)  NO chamber change.
4)  NO wheel scrub (the vehicle track width remains static at all times).
5)  NO bump steer or deflection steer.
6)  The ability to raise the ride height (by using air springs) w/o affecting track width.  This would allow the driver to set the ride height depending upon the demands of the trail/road.
Since applying for the patent I have come up with yet another advance that would allow camber change if desired.  In essence what I can accomplish with this design is BOTH positive AND negative camber.  The wheel would go into positive camber upon compression and negative camber upon decompression.  Essentially this would allow the suspension to compensate for body roll, thereby allowing the wheels to remain at 0 degrees camber at ALL times.  Furthermore by adjusting the length of the links the rate of camber change could be raised from none to a lot if desired.  If you want to get really crazy the system could be made "active" and adjust the length of said links on the fly....meaning the wheels would NEVER go out of camber even when there is no body roll.
I realize that this sounds like Pie-in-the-sky but I promise you it's for real.  I would love nothing more than to see the Sidekick be the first vehicle to get what I consider to be the worlds most advanced suspension.
Please view the attachments if you'd like to.  The steering system is drawn up for an RC car servo steering but could easily be modified to a rack and pinion type input instead.
I look forward to your feedback.
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
Re: My patented revolutionary suspension design!
« Reply #1 on: July 09, 2009, 12:57:03 PM »
Looks nice on the first glance  ;) Gotta dive in it further to see how it works.
The limiting factor for kicks however are the cv's and this doesn't help them right?
I'll dive in a bit more and will try to get some more positive critism your way  ;D
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline windahdah
  • 20
  • Sidekick JX ROCKS
« Reply #2 on: July 09, 2009, 01:15:32 PM »
Yes, no doubt the CV's are the weak point and the suspension doesn't help 'em out by offering so much travel.  To be sure some really burly and high-angle CV's will need to be used.  I never said this suspension was the cheapest but I will say that it's the best.
Please do think it over and let me know what you come up with.  Be ware though...this gets into your brain and you can't get it out.  If you're like me you'll find yourself thinking about the design at all hours of the day/night ;-).  And I hope you and many others are like me in that regard....the more the better.
« Reply #3 on: July 09, 2009, 04:42:43 PM »
With a brief look I think the biggest problem is all the moving parts.  There are a lot of things to break.
Offline ToyYoda
  • 226
« Reply #4 on: July 09, 2009, 10:10:08 PM »
If you trully care for our input, a clear draft of the suspension would help. Able to down load a steering (rough) draft but nothing on the suspension. Most of us know "less is more" when it comes to off road. Still mother nature may be your best judge.  ;)
« Last Edit: July 09, 2009, 10:20:32 PM by ToyYoda »
Offline ed oorklep
  • 637
    • Suzuki Vitara 4x4
« Reply #5 on: July 10, 2009, 05:56:31 AM »
thinking about it for like half an hour now and I think I get it now  >:D.
Problem indeed would be a lot of moving parts per wheel, with at least 10 individually pivoting parts the tolerances involved in keeping it tight would be quite hard to fab for a do it yourself guy (like all of us)
the geared version would prolly make it better though.
In theory it looks awesome indeed, but I think having only 1 degree of freedom without having any play in any way (wich is basically the strenght of the design) is also the weekness, cos it's kinda over-constrained.
once I get my 3d drawing program working again I'll draw it up and look at the effects the longer/shorter links and different pivot points have on the position and camber and stuff.
For now I'd say good thinking but a pretty complicated design with kinda collides with the kiss (keep it stupid simple) way of thinking I tend to apply  ;)
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
  • 4313
  • 167
« Reply #6 on: July 10, 2009, 08:51:25 AM »
Agree with many of the above comments - took me a while reading through and flipping back and forth from text to diagrams - but I eventually got the gist of it - showing a wheel attached to the carrier in the diagrams would have made it so much easier.
Now - the no scrub "thing" - this is dependent on the upper half and the lower half moving the exact same amount vertically, but, as far as I can tell, with the current design, there is nothing guaranteeing this.  Theoretically it will happen, but the reality may well be different.
Next - camber - this design is dependent on the vehicle chassis remaing level (horizontal) and the suspension moving in a perpendicular plane, relative to the chassis, in which case the wheel will remain at the desired camber (which is not always zero).  Consideration needs to be given to the occasions when the vehicle chassis is not horizontal, such as in a turn, when body roll may occur, especially if the vehicle is raised.
My suspicion is that this design may allow roll to tilt the chassis to the point where the negative camber on the outer wheels becomes zero and heaven forbid, even positive - by comparison - a mcpherson strut, as the chassis rolls onto the strut, and the lower arm moves upward (relative to the chassis), the negative camber increases, helping to keep the outer tire squarely planted on the road surface.
Conceivably - this could end up being a "low speed, long travel" suspension design, better suited to off road activities, rather than on road.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #7 on: July 12, 2009, 11:42:11 AM »
Wouldn't this need some sort of certification from an engineer to be used & marketed for on road use?
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #8 on: July 12, 2009, 02:20:58 PM »
How do you plan to keep the toe angle correct with this design?
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
« Reply #9 on: July 12, 2009, 03:14:47 PM »
I think the only realistic way would be to use twin hydraulic cylinders one controlling each side. or use a modified rack and pinion setup on each side connected by a splined slip shaft to a frame mounted rack and pinion.
The big question for me is, if I am looking at the drawings correctly. The design would require a big honkin horizontal lower control arm which would move up and down with the tire. It looks to me like they would allmost meet in the middle of a vehicle the size of a kick. The system would also have to be way overbuilt to withstand the beating it would take being that low and exposed.  What advantage would there be to a system which would have less under body clearance than both independent and solid axle suspensions the lack of camber change not withstanding.
Student of Now Master of Then
Offline windahdah
  • 20
  • Sidekick JX ROCKS
« Reply #10 on: July 13, 2009, 10:37:09 AM »
I really feel your concerns vis ground clearance are unfounded.
I recon the "wheel carriage" would need need to provide about a foot difference between the inner pivot points and the outer pivot points.  Basically a wider space between them provides better leverage and a shorter one less leverage, meaning if you shortened the distance between the wheel carriage pivots then you'd need stronger arms to deal w/ the added stress on the arms.
Independent designs provide better ground clearance than live axles.  They don't articulate as well, that's the rub.  My design might be slightly more vulnerable to a rock right next to the wheel knocking the wheel carraige but not much more so than any A-arm design.
In other words the "wheel carraige" doesn't need to be that long/wide at all like you describe.  Furthermore the wheel carrier could be made to be ABOVE the spindle/hub whereas most current IFS' mount em below, that could allow more "clearance".
Toe angle should be solved by the steering system that doesn't use traditional tie-rods.  Believe me, this suspension will track truer than any other design.  There will be absolutely NO bump steer.  The toe angle can be set to whatever you want and it will remain static at all times.
Offline windahdah
  • 20
  • Sidekick JX ROCKS
« Reply #11 on: March 12, 2010, 01:57:47 PM »
Hey all--
Prototype #1 of the VXI suspension is now done.  I'm working on prototype #2 currently and it'll be a major advance over #1 but still, the idea is the same.
In other GREAT news Racecar Engineering Magazine has agreed to write an article on my suspension!
Here are some pix of the Prototype #1, please feel free to give me your feedback.  Thanks...
Offline windahdah
  • 20
  • Sidekick JX ROCKS
« Reply #12 on: March 12, 2010, 01:59:09 PM »
More pix....
Offline windahdah
  • 20
  • Sidekick JX ROCKS
« Reply #13 on: March 12, 2010, 01:59:47 PM »
One more....
« Reply #14 on: March 12, 2010, 05:52:02 PM »
The steering is interesting, I wonder how well it will scale up to larger vehicles.
