Even with bad shocks, struts and tires it climbed up some pretty steep trails that were strewn with loose rocks the size of rapefruit and bigger
Econoline rear springs? What do these do? Inquiring minds want to know...
Inquiring mings really want to know what rapefruit is.
someone just had to bring it up, didnt they.
anyway, OME struts are well worth it, as they improve on every aspect of a normal replacement strut. Longer shaft travel, and superior ride and handling qualities. almost a perfect strut. (almost)
and as for GV coils, maybe its not such a good idea. 4 dr, or GV coils may give some lift, but its the spring rate that gives you lift. its stiffer than the 2dr coils, and may be too stiff. just ask 1bigtracker what happens when you run these coils. he grenaded his front diff, and the front diff being made of aluminium, doesnt help either.
