Well, I just installed the full system. It defiantly sounds better but I don't know about power and MPG yet (just put it in today). My throttle cable broke last weekend, so that also got changed today.
If anybody has already installed the Calmini header, I have a question for you…. What did you do with the warm air hose? With the old header there was a heat shield that the hose connected to, this new Calmini header dose not allow the shield to be reinstalled.
If you remove this hose, will it screw up this 'old school' attempt at an environmentally friendly system???
I moved a clamp and routed the hose next to the header…. That should give it warm air but defiantly not as hot as before.
Rodney
