noisy clutch?
noisy clutch?
leopoldsami
116
noisy clutch?
May 20, 2012, 03:59:18 PM »
OK so i was out in my 86sami on the trail today lots of rocks and very bumpy, my clutch became very stiff and was making a good amount of noise. I have tried adjusting in and out, but have had no luck. the clutch isnt even a year old. any ideas?
lv2fsh
312
19
Re: noisy clutch?
May 20, 2012, 09:22:43 PM »
Throwout bearing?
airdreams1
90
Re: noisy clutch?
May 20, 2012, 10:25:08 PM »
My thoughts exactly, but havent been able to reply all afternoon.....
Its most likely the pilot bearing or throwout bearing. did you replace either of them?
does the sound change when you push in the clutch or let it out? more info may help us diagnose it easier.
87 Samurai soft top
leopoldsami
116
Re: noisy clutch?
Reply #3 on:
May 20, 2012, 10:52:28 PM »
its only when the peddle moves. like something is rubbing
lv2fsh
312
19
Re: noisy clutch?
Reply #4 on:
May 21, 2012, 12:55:08 PM »
Cable could be going. But still maybe the TO bearing.
leopoldsami
116
Re: noisy clutch?
Reply #5 on:
May 21, 2012, 01:47:08 PM »
well damn, hopefully just the cable, i hate pulling the trans
Jonny Rash
1093
20
Too many Samurais, too little time
Re: noisy clutch?
Reply #6 on:
May 21, 2012, 03:30:56 PM »
Sounds like the cable to me as well.
25+ years of Samurai ownership!
leopoldsami
116
Re: noisy clutch?
Reply #7 on:
May 22, 2012, 07:02:09 PM »
well ill start with the cable and hope it works. Thanks for the help!
airdreams1
90
Re: noisy clutch?
Reply #8 on:
May 23, 2012, 08:29:02 AM »
If its if its posible to remove from the housing, pull it inspect it for burrs if none, then greas it & put it back in.
87 Samurai soft top
