Good question, I'm going to start working
on the rear disk brake and full floater axle
for the Track/Kicks, if all goes well, the kit
to convert will be available.
The kit which is under R&D right now is
supposed to include, larger (bigger spline count)
rear axles, parking brake rear disk calipers, a
much improved addition to drum parking brakes.
There is a question as to weather there will
be lockout hubs, or a replaced flange axle to
eliminate the weaker stock axles.
What would you guys, and gals, as a group like to
see, just a full floater axle with the flange, or to be
able to unlock a hub in the rear an have a super
easy way to flat tow ?
