« on: January 01, 2007, 04:37:28 PM »
My passenger front window is not closing properly. It goes up fine about halfway and then something binds and it starts tilting toward the front of the vehicle. The only way I can get it all the way up is if I pull the window towards the back of the vehicle while I crank the window up. I took the door apart this morning to see if there was an adjustment I could make but I came away unsatisfied. What was happening was the part that holds the window was moving back and forth on the track, as if the attachment was worn out or something. It's all back together now, but I would like to know how to fix the problem. Thanks!
01 Vitara 2.0L 5 speed, 2.5" Calmini lift, 2" body lift, Sidekick rims, locked rear, 31's, 4:1 low, 5.13 diffs <SOLD>
