Before I build a bumper next week for the back end of my Samurai, I want to make sure I've got enough lights to take care of everything I need.
While looking at the factory wiring, I came up with the following:
Reverse Light : Red Power / Black Ground
Running/Brake Light: Red Power / Black Ground / Green & Yellow for BRAKE LIGHT
Turn Signal: Green & White / Black Ground
My question is this: I want to have only two lights on each side of my bumper, a red and a white.
I want the white to be JUST a reverse light. No problems with this one.
I want the red to act as a running light, brake light, AND blinker.
How can I do this?
If I run the Green & White (blink) and the Green & Yellow (Brake) together, the blinker will work, but ONLY if I am not using my brakes.
Is there a simple way around this without buying a different light? My current light has a 3 wire plug, which wont allow a blinker and a brake unless they are combined.
I'm thinking that I could modify the light by adding another bulb/socket. Any easier ways I am over looking?
Shawn
