looking for a twin stick settup
  • 31 Replies
  • 6380 Views
Offline the joker
  • 37
Re: looking for a twin stick settup
« Reply #15 on: April 27, 2007, 05:18:36 AM »
is it posable to get the info on makin one of these myself i got lots of parts
Offline zuk jockey
  • 32
« Reply #16 on: April 27, 2007, 05:34:59 AM »
  COMMON HOW MUCH  ;D
1994 sidekick soon to have 33s
TheBigSgt
« Reply #17 on: April 28, 2007, 07:42:43 PM »
I would be interested in one too. please email me at thebigsgt|removethispart|@hotmail.com
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #18 on: April 29, 2007, 06:44:37 AM »
I think stan is selling them for $125 shipped to the lower 48. If your out of the country you will have to work it out with him. Stan doesnt know how to post pics. I will try to get some pics either tonite or tomorrow.
Mike
Offline 96Kicker
  • 1043
  • http://www.zukiworld.com/forum/gallery/3710_25_10_
    • www.myspace.com
« Reply #19 on: April 29, 2007, 10:00:44 PM »
I love my twin stick setup,works awesome ,easy install ;D
<a href="http://s220.photobucket.com/albums/dd126/fletcher9160/?action=view&current=Zuktahgreenblur.jpg" target="_blank"><img src="http://i220.photobucket.com/albums/dd126/fletcher9160/Zuktahgreenblur.jpg" border="0" alt="Zuktah club sticker"></a>TJ
#801-554-3281
96 kick 4 door with custom 3 inch susp lift and pre runner front bumper,2 inch bod
Offline jason hutchison
  • 495
  • ZUKIWORLD Staff
    • ZUKIWORLD Online
« Reply #20 on: April 30, 2007, 02:30:28 AM »
I coudn't agree more. The twin stick rocks. It makes my zuk so much more managable to drive witha  front locker. It's worth every penny.
For a dust boot I took a heavy rubber glove (like the ones for house hold cleaning). Cut it down to just two fingers. I then cut a small hole on the end of each finger and stuck the twin sticks through the holes. I zipped tied the bottom of the glove around the top of the transfer case where the groove is for the normal boot. I then wrapped some black electrical tape around the fingers on the twin stick.  It keeps the 90 w in the T-case. I freakin hate the smell of that stuff.
Offline crikeymike
  • 713
    • http://www.wazuks.com
« Reply #21 on: April 30, 2007, 04:43:28 PM »
Mike
Now i need to know what we're talking about here.  What does roughly $125 get you?  The ability to drive the front or rear drivetrain independantly?  Or is this for gear reduction?
1993 4-door Sidekick
4.24:1 t-case
Offline 96Kicker
  • 1043
    • www.myspace.com
« Reply #22 on: April 30, 2007, 05:00:14 PM »
It allows you you to disengage your front end, but still have the capability of low range in 2wd.
#801-554-3281
Offline biker
  • 730
  • It's a sickness I tell ya
« Reply #23 on: May 02, 2007, 09:04:44 PM »
Are there any mods to the t-case needed or is it a drop in mod? Any luck with those pics Mike?
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #24 on: May 02, 2007, 10:05:13 PM »
I was over there and forgot.  ::) I am going back over tomorrow, I will try not to forget this time. :P The case needs to be separated to remove one detent ball. If your doing a 4 to 1 you already have that ball out.
Mike
Offline Element
  • 1902
  • LillyKicker
« Reply #25 on: May 02, 2007, 10:09:16 PM »
I want a twin stick for my sami!!!
 :'(  I feel left out!
Jerry                                                               Member since:   May 14, 2006
zUkTAH
U4WDA
Offline Mikerpm4x4
  • 2875
  • 12
    • www.rpm4x4.com
« Reply #26 on: May 03, 2007, 10:26:29 PM »
here is what it looks like out of the truck.
Offline Jeff@TireBalls
  • 559
« Reply #27 on: August 04, 2007, 06:44:32 AM »
Did you get any pics of them installed? Will they fit a Grand Vitara?
2000 Grand Vitara Limited, 2" lift, 225/75-16 BFG KO's, 5.12 gears, Safari snorkel, roof rack.
1987 Samurai LWB, VW 1.9 Turbo Diesel.
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #28 on: August 04, 2007, 03:52:56 PM »
Mike
I have my case out at the moment as a set of Trail Tough's crawler gears have just gone in along with a full rebuild and I have had the output drilled and tapped  so I can do a SYE and possibly put a rear disconnect on it. It's all back together but not in the Kick. I didn't do the install so I didn't know about the detent ball needing to be removed. If this is the case and it has already been done, will I need to open the case up again or can I just swap in the Twin stick? This would be the icing on the cake if I can just drop it in because then I could put the t-case back in and just swap in the sticks when I get them without having to pul the t-case again.
Offline 37kicker
  • 319
  • 97 tracker 9inch front and rear on 40" pitbulls
« Reply #29 on: August 04, 2007, 07:53:08 PM »
you will have to split the case & remove the d-tent ball still.  stan
