You can get a 4:1 transfer case kit for the Tracker/Sidekicks. It's low range only, but it does drop you down to a proper trail gear. The stock 2:1 is a bit high...
Fixed.
And, so we're clear, it's an
additional $2000 to go from 31" to 33". It's easily $2000 to
properly go from stock to 31" tires.
Tires & Backspaced / Wider wheels: $90 x 5 = $450
Swampers (some of the cheapest M/T) = $1000 mounted, balanced & insured
(Note, we haven't even gotten to the lift yet and we're at $1,500 already)
SPOA kit & shocks = $600+
Over the top steering = $300
T-case gearing = $400 - $800 (depending on sales, if you elect to get $100 strengthened front output shaft, rebuild kit, oil etc)
Total = $3,500-$4,000This isn't taking into account loaded costs (Shipping, special tooling etc), or "hommie hookups" so obviously the price will fluctuate depending on how lucky / unlucky you are. Nor is it including other things that should probably go with larger tires: bumper & swing away carrier, rock rails, lockers (which, if you're wise, you'll have already installed)...
