need more tracker power
  • 9 Replies
  • 2435 Views
« on: April 22, 2009, 01:40:36 PM »
have 91 tracker need more power have cold air intake up grading to 31 boggers but need more power?
just wondering what i could do to get more power for cheap or gears?
Offline Lindenmooch
  • 560
Re: need more tracker power
« Reply #1 on: April 22, 2009, 01:47:38 PM »
My 91 Tracker is painfully slow....I'd like to see what people suggest for quicker acceleration and/or overall performance on the road.
I had a "cold air" or short ram aftermarket intake on my tracker....sounded cool...but actually hurt my throttle response, and with some mudding, I feared getting water in the engine, so I scrapped it.
« Reply #2 on: April 22, 2009, 02:00:02 PM »
Gearing is essiential. Turbo don't hurt either.
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #3 on: April 22, 2009, 02:10:32 PM »
There's this guy, goes by 95XL7.  Drop him a line.
XL-7 front coils
1.5" rear coil spacers
« Reply #4 on: April 22, 2009, 03:26:55 PM »
Gearing is the achelles heel of the tracker world - especially when it comes to 31" tires.
« Reply #5 on: April 22, 2009, 03:59:08 PM »
so it has proper gearing for 31"s im running 235 75 15 seems very under powered in 2nd gear 4 high
Offline Hillbillydave
  • 213
« Reply #6 on: April 22, 2009, 04:21:14 PM »
There are no aftermarket gears for the trackick's that will help the high range. The only option is to change out the ring gears and pinions. If you have an automatic, chances are you have 4.67's, and you can swap the 5.12's from a manual kick. If you have a manual trans, you are pretty much stuck with what you have unless you can find a set of 5.62's or 5.38's. But these are scarce as hen's teeth and if you do run across them, they will be used.
'89 sidekick 1.3L 3" blue suspension parts, custom strut extensions 31x10.5 Mud Trac's on 10" rims rear fenders trimmed, lincoln locked rear, Rochester Carb on custom adapter
93 Sammy project, SPOA with 34's, 5.12's, welded, in the works
« Reply #7 on: April 22, 2009, 04:38:14 PM »
 ???i have 5 speed manual so 5.12?? so go t case gears and what r they worth and im from canada where would i find them??
« Reply #8 on: April 22, 2009, 04:40:25 PM »
which years of trackers had the 5.62 or the 5.38 so i can start looking for some
  • 213
« Reply #9 on: April 22, 2009, 09:19:40 PM »
89 sidekick with the 1.3L has the 5.62's.
Transfer case gears will not help on the road. They only reduce the low range side, therefore they would help considerably off road.
Check with the sponsers of this site for tcase gears and other goodies.
