lengths of coils...?
  • 1216 Views
Offline museboy07
  • 641
« on: April 15, 2007, 09:08:58 PM »
What is the length of a 2 door tracker coil spring, 4 door spring, and GV spring?
Offline tipover
  • 422
Re: lengths of coils...?
« Reply #1 on: April 15, 2007, 09:16:58 PM »
My 95 four door springs are:
fronts 10.75 inches
Rear 12.5 inches
thats all I know
RV Dingy-2003 2 door tracker
RV- 31' Monaco Mckenzie
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #2 on: April 16, 2007, 01:42:50 PM »
Length won't tell you much.  You actually want to know the whole picture like lengths, wire diameter, and especially spring rate.
If I can recall correctly OME's XL7 spring is actually a hair shorter than it's GV spring.
Offline bzzr2
  • 1011
« Reply #3 on: April 17, 2007, 09:57:41 AM »
according to arb's ome info the gv spring is 30mm longer the the kick front coil, no idea about the rear.
09 taco reg cab short box 4x4
« Reply #4 on: April 17, 2007, 03:23:37 PM »
I know the OME "heavy" rated spring is a 540 lb spring rate,  and new has a free length of 11".
