sticky diffs
  • 1618 Views
Offline wheresmyhat
  • 244
  • 16v here I come baby!!!
sticky diffs
« on: September 18, 2006, 10:10:26 AM »
 :-X :-X :-X
How do you separate the diff from the axle housing without beating up the 3rd housing.
this has never been removed so its the factory gasket material.
Thank you
Nathan
86 sami 87 motor and a few other years in there probably, dana 44 rear,36"tsl. I once had splitfire spark plugs.
Offline toomeymd
  • 296
  • I Love ZUKTAH!
Re: sticky diffs
« Reply #1 on: September 19, 2006, 07:42:12 PM »
I'm assuming you pulled the axles already? If so, the silicone will hold it up a bit, smack it (not too hard) with a good hammer, it should break the seal, and you can wiggle it out.
Suzuki Rocker
Offline 4njeep
  • 113
  • I Love ZUKIWORLD!!!!
Re: sticky diffs
« Reply #2 on: September 19, 2006, 10:40:35 PM »
i had the same problem a couple months ago. it took me jacking up the front of the diff, and beating on it with a hammer. if that doesnt work. get a bigger hammer ;D
that should loosen it up enough that you can pry it apart.
P.S. i used a rubber hammer, and dont forget to pull the axels out about 5 or 6 inches.
92 sidekick jlx auto
2" suspension lift
5.13 gears, locked rear.
30x9.5 goodyear mt/r's on CSA Scorpion's
Offline wheresmyhat
  • 244
Re: sticky diffs
« Reply #3 on: September 21, 2006, 02:38:30 PM »
Okay finally got them both out.   ::)   The back was such a pain. I thought the front  was going to be the same way so I pulled the axles, unbolted the carrier from the housing. It was still connected at the driveshaft and frame mount. Came back to it after a few minutes and found that it had separated itself enough to drain all the oil onto the floor of my garage  :-\ . I wasnt able to loosen the drain bolt. I had a pan under there to catch the oil when I was ready to separate it but it had gotten pushed over just enough not to catch any of the oil.  Next one I will be ready for.  ;)
Anyone know why the rear diff is 15 pounds heavier then the front  ???
Re: sticky diffs
« Reply #4 on: September 22, 2006, 04:32:00 PM »
Rear diff is a bigger gear, and the carrier is iron,
not aluminum
