wut needs to change to run 33's
  • 8 Replies
  • 1740 Views
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« on: October 16, 2007, 11:02:45 AM »
hey im doin a body lift going to runn 30's for my daily driving and 33's on the trails.  i beleive to have 5:12s but not sure though i have 94 1.6 16v 5 speed is my setup.
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Re: wut needs to change to run 33's
« Reply #1 on: October 16, 2007, 02:44:10 PM »
Yup.
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
« Reply #2 on: October 16, 2007, 04:39:33 PM »
If you want to run 33's you are going to have to make a lot of changes. Including gearing and trimming.
Student of Now Master of Then
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« Reply #3 on: October 17, 2007, 11:26:17 AM »
such as?  wut about 32's.
  • 416
  • Lil Suzys Dad
« Reply #4 on: October 17, 2007, 11:59:09 AM »
OK, start with 6 inches of lift, Calmini is the best, add the Hagen Widening to move the front tire out and forward. Trim back the front fender. Trim back the front bumper or replace with aftermarket. Extend the bump stops if needed to limit up travel rubbing. Adjust the steering stops to keep the tires off the frame. Install a 4lo kit in the transfer case. Install 5.83 RP's if you can find them. After that the rear axle over rotation, CV upgrades, rear axle shaft upgrade, OME struts, engine mods, clutch upgrade, locker install, rockrail install, skid plates, etc. are up to you.
32" tires? see above.
Offline satan inside
  • 68
  • bodylifts are for rednecks
« Reply #5 on: October 18, 2007, 08:41:45 PM »
The stock 3rd member held up fine for me with 31" boggers. That is untill i got all 4 tires onto solid rock. Replace it with a steel one.
Offline da_tub
  • 307
« Reply #6 on: October 18, 2007, 09:29:18 PM »
hey thats a nice pic....lol
91 four door ,and some stuff
Mudjockey#1
« Reply #7 on: October 19, 2007, 07:41:19 AM »
Now thats CARNAGE!!! 8)
Offline JayN
  • 220
« Reply #8 on: October 19, 2007, 09:05:24 AM »
i had soem 33x12.5's on my kick, with a welded rear and it worked greta except for it was real hard ont he clutch if i was on tight trails.
96 sport, safari rack, lift
1970 gmc truck
1950 dodge truck
1974 corolla
