First impressions:I found that it had a very strong low to mid range. Top end did not show anything faster than stock, but getting there was pure enjoyment! The throttle response is something that you have to get used to. It is veeery responsive! Don't stomp the pedal unless you are already ready to shift. This kit will teach you how to drive again. {grin}
Dyno tests showed that we had a 20+hp gain over a stock carburetor, and a 10hp gain over a well setup Weber carburetor. Throttle response is instant, and power is felt throughout the power band. On road we had a stock car doing well over 80mph on the freeway up an incline. Off-road it is a dream, you can idle along at 900rpm and have plenty of on demand power to get over/up or through any obstacle. We found our gas mileage ranged from 29 to 35mpg with normal freeway speeds, and around town stop and go trips.
These look way cool. http://www.samuraiguy.com/
I would be really leary of using a copper gasket on an Aluminum engine, particularly in the presence of coolant. Copper and Aluminum produce a small electric current when they are touching and in the presence of watter. This small electric current accelerates a chemical reaction between the two and the result is massive corrosion. I've seen this happen with aluminum CPU waterblocks that have a copper "cold plate" that touches the CPU. Generally, the seam where the copper and aluminum touch will corrode all the way around and the seal will fail.
