Why Ford 9" in kick rear?
  • 13 Replies
  • 2192 Views
Offline ZeusZuki
  • 411
« on: July 07, 2005, 06:48:11 PM »
So why do you guys stick the Ford 9" in back? ???
Re: Why Ford 9" in kick rear?
« Reply #1 on: July 07, 2005, 07:22:49 PM »
Beefy and gear ratios match the 5.83
front Calmini diff gear
I don't have one but there
are several here that do
Offline bhaugen
  • 140
« Reply #2 on: July 08, 2005, 12:23:50 AM »
Any of you running the Hi-9.  http://www.truehi9.com/  He is from my area and I have seen it Good strong product.  Didn't realize anyone was running a Ford 9" in a tracker.   I thought it would be overkill.
« Reply #3 on: July 08, 2005, 09:07:06 AM »
I was beaking rear shafts on a regular basis when I had my stocl rear end wirh a 4:1, 5.83's and 33's. The stock shafts just could not hold up to my abuse. A friend fornd me a used Currie Ford 9" ready to go (locked, alloy 31spline shafts, reinforced etc...)besides me matching the gearing. We got that sucker in there and I have not had to think about blowing a shaft sine then ;). It may seem like crazy overkill but many people think I'm nuts for building a sidekick ::) Not to mention it will have plenty of strength to grow the Kick over the next few years. :)
Offline toolman21
  • 229
  • 89 Kick with 5" lift and 30's
« Reply #4 on: July 08, 2005, 09:34:22 AM »
How much do you have to shorten it to fit it under the kick?  Or is there something that has the right dimensions?
Toolman
Offline 1bigtracker
  • 3409
« Reply #6 on: July 08, 2005, 12:23:31 PM »
My Currie was built for a Jeep Widetrack width, which is 1.5" Narrower that a stock Kick axle, So I added 1.5" spacers on each side to make it 1.5" wider than stock.
Offline jason hutchison
  • 495
  • ZUKIWORLD Staff
    • ZUKIWORLD Online
« Reply #7 on: November 09, 2005, 02:48:55 PM »
I am sure this is posted somewhere.
What is the standard width of a sidekick rearend? flange to flange..
Offline SnoFalls
  • 1358
« Reply #8 on: November 09, 2005, 02:51:54 PM »
58" WMS-WMS
Offline b1pig
  • 61
    • Jeep
« Reply #9 on: November 09, 2005, 03:30:18 PM »
This looks very interesting, guys.
I had actually considered looking up a D30 from a CJ and usinga  D35 I have laying in the back yard. I already have a couple of D30 housings, but they are left side diffs.
I also have a 9" from an unknown year Bronco laying in a yard a few miles from here. Worth the though.  hhmmmmmmmmm....
b1pig
'90 Tracker, '07 JK Rubi
Offline SnoFalls
  • 1358
« Reply #10 on: November 09, 2005, 07:03:28 PM »
CJ's are typically 53" WMS? ... and a D30 isn't any stronger than the stock zuk stuff.
A furd 9 is a decent choice for a rear, if you're looking for an up front mate for it, then a D44 would be good. Getting gears to match front/rear may be the limiter ...
Offline 37kicker
  • 319
  • 97 tracker 9inch front and rear on 40" pitbulls
« Reply #11 on: November 10, 2005, 05:45:09 PM »
the bobtail broncos are a little wider than a kick around 2" if i remember correctly . the best thing about a 9" is parts availability & after market / beef up parts ,plus you have a huge selection of gear choices. i'm running a 72 bronco rear 6.50 gears & spool with 28 spline .this winter i'm going with a fullsize bronco rear with 31 spline axles  so it should be bomb proof ;D  stan
« Reply #12 on: November 11, 2005, 08:41:00 AM »
You looked pretty bomb proof when you
pulled Ross and I out of Golden Spike   :)
Loved your Track/Kick
  • 495
  • ZUKIWORLD Staff
    • ZUKIWORLD Online
« Reply #13 on: November 12, 2005, 07:52:29 PM »
Well all this talk of 9" rear ends got me searching. I searched the local classifieds and I picked up a used ford 9" out of a 1964 lincoln (so the story goes) from this super cool old guy in Escondido california.  He has already pulled it apart cleaned and painted everything..  It's 28 spline 5 on 5.5. It's 57" form flange to flange so once the axles and and everything is mounted I am figureing about 61 " wide. I got the Ford 9" and a Hawaiian surf company 6'6" surfboard for 100 bucks.. Gotta love old surfer hotrod dudes!
