Will this make me fail emissions test?
  • 12 Replies
  • 2250 Views
Offline keith
  • 1176
« on: May 24, 2004, 01:37:37 PM »
When they do the gas cap inspection during an emissions test I am wondering if the tester will notice my filler neck and fail me.  I am thinking of putting some RTV filler over the holes, maybe in black.  What do you guys think?  What should be where the white caulk is?
Offline jagular7
  • 1026
  • Jagular7
Re: Will this make me fail emissions test?
« Reply #1 on: May 24, 2004, 02:34:51 PM »
When I lived in Virginia, they would pull off the cap and make sure that I didn't mess with the hole design of the fill tube, whatever for ?? as there hasn't been leaded gas available for dozens of years.
Since you last inspection, did they?
What state?
Lenexa, KS
Offline keith
  • 1176
« Reply #2 on: May 24, 2004, 03:38:45 PM »
Illinois.  I haven't had this vehicle inspected before.
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
« Reply #3 on: May 24, 2004, 04:17:08 PM »
When the fuel cap test is performed they fit your cap to an adapter that hooks to the test pump which tests the cap for leaks. They may not even notice the filler neck but I would recommend replacing it because it could lead to other problems such as rotted out fuel tank or water in the carb.
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
Offline mavapa
  • What, no personalized text?
« Reply #4 on: May 25, 2004, 02:13:35 AM »
If the filler neck is connected to the tank with a rubber hose, or if it can be disconnected easily in some other way, I suggest that you get a new one. You should be able to find one at a junkyard that's in better condition than yours.
Offline trackermad
  • 150
« Reply #5 on: May 25, 2004, 05:14:49 AM »
 Gas will melt RTV!
"First of all: what is work? Work is of two kinds: first, altering the position of matter at or near the earth's surface relatively to other such matter; second, telling other people to do so."  ~Bertrand Russell
Offline dschwab9
  • 61
    • Zuwharrie.Com
« Reply #6 on: May 25, 2004, 09:21:43 AM »
In GA, they take the cap off and put it on a thing that presurizes it and checks leakdown.  They don't look at the filler neck on the truck at all.
Derek Schwab
Where The Road Ends...Zuwharrie Begins!
http://www.zuwharrie.com
http://bbs.zuwharrie.com
Offline mavapa
« Reply #7 on: May 25, 2004, 10:11:25 AM »
They may not look, but from the looks of the picture, they won't be able to pressurize the tank for all the rust holes. I still vote for a replacement filler neck.
Offline DaddyDave
  • 204
  • Indeed
« Reply #8 on: May 25, 2004, 10:56:27 AM »
i vote replacement filler neck...ditto on the gas v. rtv....gas wins!! :D
"The maximum effective range of an excuse is 0.0 meters."
95XL7
« Reply #9 on: May 25, 2004, 11:08:16 AM »
Call Hawk Suzuki probely only charge ya a few bucks plus shipping. ;)
Offline 87BlackSami
  • 191
« Reply #10 on: May 25, 2004, 03:45:18 PM »
FYI: They pressurize and draw vacuum on the cap, not the filler neck.
Offline mavapa
« Reply #11 on: May 26, 2004, 02:04:08 AM »
OK, I see. No pressure on the tank.
But I still vote for a new filler neck.
Besides, I always fill mine up till I see gas. If I had those holes in my filler neck, I would be pumping gas all day.
Offline explosivo
  • 3157
« Reply #12 on: May 26, 2004, 05:08:41 AM »
I vote for new filler neck... cheap insurance :-/
omghi2.us[/url]
