my sidekick('89) came with a/c also.convertible. go figure.it worked fine, but i have removed most of it.question: what all is inside the ducting/fan stuff behind the glove box? i've never been in there and am considering pulling that radiator part out if i can without causing big headache like removing dash or......
Quote from: rascott on April 20, 2009, 05:29:45 AMmy sidekick('89) came with a/c also.convertible. go figure.it worked fine, but i have removed most of it.question: what all is inside the ducting/fan stuff behind the glove box? i've never been in there and am considering pulling that radiator part out if i can without causing big headache like removing dash or...... the radiator thing (AKA the heat exchanger) is pretty easy to pull out. it is in the section between the fan and the heater core. you will need a replacement duct from a non-A/C sidekick to put back in the hole
Well it dose still work.(checked it this weekend) and I think having on board air is a good idea. (also needed this weekend, I had to pack a compressor). so are there parts i need or what, I'm sure it's not just adding fittings.
