rod bearings
rod bearings
bluezuki87
7
rod bearings
September 30, 2008, 08:53:52 PM »
anyone had there rod bearings start making noise really bad on them? my dad thinks there is a little bit of a rod knock in the engine but i am not 100 percent sure. i am going to ride with it for a while and see what happens. i think the valves may need to be adjusted some too so that could be it also.
87 Suzuki Samurai soft top
mrfuelish
2862
13
you must have a perception problem.
Re: rod bearings
September 30, 2008, 10:35:11 PM »
Just do A oil change and listen when you first start it up, if it rattles for a second then gets Quiet then there is a problem, mine starts Quiet even with no oil in it starting up dry.
1987,1988,1988,1990 samurai's, 1953 m38a1, 1996 x-90,blue.1996 x-90 red.1994 2 door tracker. only Dead Fish go with the flow. No Hairy Nosed Wombats were ran over on the trail today. My ZUK is Xenophobic.
