i maxed out an rti ramp!!
  • 19 Replies
  • 5213 Views
lucszuk
« on: March 16, 2004, 08:58:02 AM »
i had never ever even tried my rti on a ramp and expected to get practicaly no where i went halfway up and stopped expecting my samm  to be maxed and my friends just  yell keep going u idiot i ended up maxing it ouy and i could have keep going i never noyiced i had that much flex since i didnt build my sammi for rocks.
(ps my susupsensions is: 6 inch spoa 3 inch old man emu spreing shackle reversal 3 inch body lift with 35's)
Offline shoyrtt
  • 161
Re: i maxed out an rti ramp!!
« Reply #1 on: March 16, 2004, 10:49:08 AM »
Pictures man, Pictures! The world needs your pictures!
Offline Mike71
  • 1449
« Reply #2 on: March 16, 2004, 11:24:48 AM »
hey whats an RTI ramp? i know it is for articulation so asssume its like a wedge shaped thing..but why is it called an RTI ramp?
623hp kb cobra sold! 100hp kick new DD :P
Offline jagular7
  • 1026
  • Jagular7
« Reply #3 on: March 16, 2004, 11:55:33 AM »
Ramp Travel Index. It's a measurement percentage of the wheelbase vs the up travel of the tires on the ramp/ground before one tire comes off the ground. If you travel 1/4 up to the wb, you are 25%. If you climb all the way up, you reached 100%. If you have to approach the ramp at an angle so that your rear tire doesn't climb the ramp, you've better than 100%, numbers of 1050, 1100, 1150, etc. It's still a percentage but represented as a whole number.
23 degrees was the initial fame in the 90's. Now there are trucks maxing this out easily, so 25 degrees was next and since it wasn't a drastic change in degrees, easily conquered. Now the theme is 30 degrees.
Lenexa, KS
Offline Mike71
  • 1449
« Reply #4 on: March 16, 2004, 12:21:57 PM »
ah i c..thank you for that really really good explination
lucszuk
« Reply #5 on: March 16, 2004, 01:40:42 PM »
there was no cameras around , i didnt expect to be doing it i was drivinf down portage and there was a car show with a jeep like half way up so i decided i should go show him up (or a least try with my 2000 dollar rig) and ya just did and they guy was all like ya well mine has no rust and stuff
lucszuk
« Reply #6 on: March 16, 2004, 01:41:49 PM »
i have just realised i have NO pics of my rig after i built it.. olnly stock and a couple of my lj 80 in mud
« Reply #7 on: March 16, 2004, 10:12:47 PM »
Here's one
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #8 on: March 16, 2004, 11:43:46 PM »
This was at a Toys for Tots drive before Christmas.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline Yankee Tim
  • 431
    • Yankee Off-Road
« Reply #9 on: March 16, 2004, 11:48:09 PM »
Well, not exactly.
RTI is bases comes not from th distance in inches or feet you travel up the ramp, but rather it is based on the wheelbase of the truck.  A 1000 score is based on traveling up the ramp the same distance as the wheelbase.
If a Truck with a wheel base of 88" traveled 88" up the ramp before lifting a tire, that would be a perfect 1000 score.  If the next truck had a wheelbase of 100", and maxed out a 88" on the ramp, it's score would be 880 RTI.
Here's the fomula:
Distance traveled in inches ÷ wheelbase in inches x 1000 = RTI
There are many different degree ramps, from anywhere from 20* to 35*.  The more the * in the ramp, usually the lower you RTI score will be.
Ramping 1000 on a 20* is MUCH easier than on a 35*.
Hope this clears things up.
Yankee Tim
Offline 1bigtracker
  • 3409
« Reply #10 on: March 17, 2004, 04:07:17 AM »
is a 66? good for a tracker?  That what i ramped at the Jambo.
Stu
Offline TinTopper
  • 73
  • 1987.
    • dayid.org
« Reply #11 on: March 17, 2004, 05:24:09 AM »
I've always heard that rather than distance UP the ramp, it's how high your tire is lifted in the air before another lifts off the ground..., with wheelbase taken into calculations
That way, scores are actually comparable regardless of the ramps degrees...
'87 TinTop
'04 F-150
Offline Mike71
  • 1449
« Reply #12 on: March 17, 2004, 07:45:23 AM »
Here's one
thats what i thought it looked like..what wil a stocker do =) lol
lucszuk
« Reply #13 on: March 17, 2004, 12:20:23 PM »
u lifted a tire tho....
Offline 92Sidekick4x4
  • 1456
« Reply #14 on: March 17, 2004, 12:52:29 PM »
obvoiusoly it is maxed out then
