old thread, i know, but there are so many on this topic already, i cant see the pro's of starting a new thread.
well, i tried to make new drop brackets for the front diff to lower it, or rotate it.
doesnt work.
if you lower the front of the diff 2", the rear mount binds too much, the pinion flange points upwards, may hit the sump under load, and the steering arms may hit the diff.
apart from that, just making longer drop brackets will not work. they do not fit properly on the left hand side. the right hand side is easiest, but the left, because it is mounted to the front of the diff, needs an angle in it.
so, maybe 1" - 1.5" may be max drop on the two brackets.
has anyone made any yet? or tried? i'm very interested to see how other did theirs. anyone?
and i'm also thinking about strapping the pinion down too, good idea?
thanks
