WEBBER CARB ?'S
  • 1732 Views
Offline AZMIKE
  • 6
WEBBER CARB ?'S
« on: September 16, 2006, 10:55:10 AM »
NEW TO THE FORUM. 1ST POST. ILL TRY TO SPELL CORRECTLY.
BOUGHT A 87 SAMI. 1.3L REBUILT AND BORED OVER, ISKY CAM, HEADER, WEBER CARB.
THE WEBER IS A 32/36 DGV MANUAL CHOKE. FORMER OWNER SAID IT NEVER IDLED RIGHT. WHILE DRIVING IT WOULD GO FROM STALLING TO IDLE REVS AT 2000 RPMS.
IM TRYING TO ADJUST THE ILDE. FOLLOWING ALL THE INSTRUCTIONS BUT NO LUCK.
MY 1ST QUESTION IS ABOUT THE VACUUM LINES.
THERE IS A VACUUM LINE CONNECTION ON THE CARB NEXT TO THE IDLE MIXTURE SCREW. IS IT SUPPOSE TO BE CONNECTED TO SOMETHING? MINE IS CAPPED OFF WITH A RUBBER COVER. DOSENT LOOK RIGHT TO ME. IF ANYONE KNOWS THE ROUTING OF THE VACUUM LINES I COULD USE THE HELP.
FOR THOSE OF YOU WITH THE WEBER CARB, DID YOU GET RID OF THE CANISTER? IF SO WHAT DO YOU CONNECT THE DISTRIBUTOR VACUUM LINE TO? MINE IS CONNECTED TO THE CANISTER.
LAST QUESTION. THE FUEL INLET ON THE CARB IS BIGGER THAT THE STOCK FUEL PUMP INLET. I HAVE A 3/8 FUEL LINE FROM THE CARB TO ONE OF THOSE CHEEPO CLEAR PLASTIC FUEL FILTERS. THEN A SMALLER DIAMETER HOSE FROM THE FILTER TO THE FUEL PUMP. AGAIN THIS DOSENT LOOK RIGHT TO ME.
87 SAMIURAI
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: WEBBER CARB ?'S
« Reply #1 on: September 16, 2006, 12:18:49 PM »
The first thing that sounds very wrong from the above description (aside from the SHOUTING -- bad netiquette   ;) ) is the fact that the distributor advance vacuum line is connected to the cannister.
The distributor vacuum advance (marked by the red arrow) should be connected to the port on the carburetor just below the choke mechanism (yours may look different as it is manual) next to the adjuster screw as seen in the picture.  If things look "funny" as how my carb is mounted, that's because it is installed backwards to reduce stalling while climbing steep inclines.
All other vacuum lines on the manifold should be closed off. Edit:  Sorry, that should read "All other vacuum lines other than the one that drives the brake booster should be closed off."  Sorry about that...
For more information on setting the idle, do a search for weber at Ack's FAQ (a link is in my signature).  There you will find a link to an article at iZook.com on weber tuning by the master, Sarge.  You will also find a link to Sarge's website and a pdf copy of the Weber installation and maintenence manual.
Hope this helps!
« Last Edit: September 17, 2006, 01:51:41 PM by ack »
Ack
Offline Terry329
  • 59
Re: WEBBER CARB ?'S
« Reply #2 on: September 16, 2006, 12:23:32 PM »
yup, he beat me to it,...the vacuum nipple on the bottom of the carb itself is connected to the distributor advance vacuum,...that will solve a world of problems...the only thing that goes to my charcoal canister is the rubber hose fuel line from where the main fuel line goes into the carb....
good luck
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
Re: WEBBER CARB ?'S
« Reply #3 on: September 17, 2006, 08:04:19 AM »
ya that vacume line off tha weber goes to the distrib.  thats the only one u need... might help some..lol as far as the canister I left it there hooked up, but capped the middle line off since its not really in use anymore.
Offline AZMIKE
  • 6
Re: WEBBER CARB ?'S
« Reply #4 on: September 17, 2006, 09:42:26 AM »
thanks to all for the help. now ill be able to set the idle correctly.
special thanks to ack for taking the time to post the pic.
87 SAMIURAI
Offline AZMIKE
  • 6
Re: WEBBER CARB ?'S
« Reply #5 on: September 17, 2006, 09:47:07 AM »
oh ....sorry about the SHOUTING. i didnt know...now i know
87 SAMIURAI
