How common were the 1.3 sidekicks
  • 9 Replies
  • 2002 Views
Offline urbanwheeler
  • 696
« on: May 30, 2007, 06:41:22 PM »
I was wondering how common the 1.3 sidekicks were, and if they were comparable to the samurai in performance.
Offline Digger
  • 1991
  • 1996 Suzuki X-90 4X4
Re: How common were the 1.3 sidekicks
« Reply #1 on: May 30, 2007, 07:14:02 PM »
I would venture a guess that they are pretty rare. I know I've never seen one and I've looked! LOL! I've looked hard for one in a junk yard because I want the 5.38 thirds out of it!
Offline TrakJD
  • 232
« Reply #2 on: May 30, 2007, 09:59:19 PM »
5.62 not 5.38  ;D
Factory made
4.62 (automatic)
5.12 (Manual)
5.62 (verrrry rare)
However we do have 4.56, 5.38 (but this is made for Suzuki Samurai I believe) and 5.89 gears (all are aftermarket)
Calmini most likely carry 5.83 or 5.89 gears for sidekick/tracker but they are hella pricey...  almost $300 for one side I believe.  4.56 and 5.38 should range from 175 to 200.
Now, you know the options.....
« Last Edit: May 30, 2007, 10:21:12 PM by TrakJD »
copperfever
« Reply #3 on: May 31, 2007, 07:23:57 AM »
There is a 1.3 sidekick in the junkyard where I live. I have used some engine parts off of it for my sammy. The trannsmission and transfer case are gone but it seem to be pretty much complete otherwise.
Offline locjaw
  • 2045
  • 22
« Reply #4 on: May 31, 2007, 07:33:22 AM »
you better go pull the thirds and sell them to someone on this board >:D
jason
« Reply #5 on: May 31, 2007, 07:21:41 PM »
From everything I have read/heard, the 1.3 carbed engine they used WAS the samurai engine.....so that would make them very comparable to a samurai performance wise....the 1.3 sidekicks used 5.625 diff gears, I'm assuming because they weigh more than a samurai, the lower gears were needed to keep the "performance" up.
« Reply #6 on: June 01, 2007, 10:06:40 AM »
I would have thought that the extra size and weight of a Track/Kick would really hurt the performance.
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #7 on: June 01, 2007, 03:03:06 PM »
The 5.38's were in the early 8v 5 speed 4-door trackicks
I'm wondering if you could actually get these from the dealer, and for what price!... just out of curiosity.
« Reply #8 on: June 01, 2007, 03:50:47 PM »
You are correct, the 5.38 factory gears came in the 91, 4 doors, with 5 speeds and the 8V engine.
The aftermarket makes the 5.38s for a samurai....which would net you a front gearset for a trackick...but it is the rear gearset for a trackick, that is hard to get.
Offline TrakJD
  • 232
« Reply #9 on: June 03, 2007, 11:25:16 PM »
As for the 5.38?  in 1991 tracker?  Damn.  I didnt know that factory made those.
