« Reply #12 on: June 10, 2009, 10:18:57 PM »
Stock header is crap, there's no need in 2" or 2"1/4 exhaust if you operate stock header. Keep your glasspack, just put the glasspack in the middle. Glasspack = no flow restrictions and good sound absorbing.
Example: header -> flex pipe -> glasspack -> backpressure(if neded) -> piping-> muffler-> end piping.
Is it necessary to go with catalityc converter in Canada? Asking cause I have none and still pass Euro3 emission tests.
« Last Edit: June 15, 2009, 10:01:57 AM by Dimitros »
95 Samurai, 1.3, high comp.pistons, ported/grinded head, 1.6 valves, bored intake, Solex carb, K&N air, MSD Coil-Blaster+MSD 8.5 wires+Denso Iridium IW16 plugs, Calmini Tri-Y heder, Cherry-Bomb+Bosal custom exhaust, GRS II 4.89 T-case, 3.92:1 R&Ps, Calmini 3.5" susp., 30" BFG ATs, AVM 538 hubs...
