Help with a couple of ?s on 16v swap
  • 18 Replies
  • 4405 Views
Offline 96Kicker
  • 1043
  • http://www.zukiworld.com/forum/gallery/3710_25_10_
    • www.myspace.com
« on: November 30, 2007, 06:28:43 AM »
Ok my 16 valve swap is mostly complete except a couple of vacum hoses.
Ok the stock charcol canister on my sammy has 3 hook up points, I know one is a vent line from the fuel tank and the other two are ????? Do I plug these or hook them up some where.
TJ
<a href="http://s220.photobucket.com/albums/dd126/fletcher9160/?action=view&current=Zuktahgreenblur.jpg" target="_blank"><img src="http://i220.photobucket.com/albums/dd126/fletcher9160/Zuktahgreenblur.jpg" border="0" alt="Zuktah club sticker"></a>TJ
#801-554-3281
96 kick 4 door with custom 3 inch susp lift and pre runner front bumper,2 inch bod
Offline mrfuelish
  • 2862
Re: Help with a couple of ?s on 16v swap
« Reply #1 on: November 30, 2007, 08:01:30 AM »
If I can remember I think mine was swaped out for the one off the 16 valve and it only had two lines, one large one for the gas tank and a smaller one that went to one of the solinoids on the front of the engine, will have to check for ya when it warms up a little. 22 deg. out I know put a coat on.
Offline goodyz
  • 133
  • Turdzuki.
« Reply #2 on: November 30, 2007, 08:10:10 AM »
One of those ports is supposed to go to a tiny solinoid, and from there to a vacuum port on the intake manifold. The solinoid opens breifly at start up to suck the stored fuel vapors out of the canister. Hopefully your 16v came with all that stuff still on it. On the front of the intake mani. there should be a little steel tab bolted on with two baby solinoids. hook it up to the one with the black body, and find the corisponding electrical plug on your new harness and plug that in too. The larger of the three ports vents to the air (a fail safe?) I think, someone wanna' chime in here?
Anyway yes one to the tank, one to the solinoid, then to intake and one to the atmosphere.
Or if you don't have e-testing FUGETABOUTIT!
-goodyz
Offline goodyz
  • 133
  • Turdzuki.
« Reply #3 on: November 30, 2007, 08:12:25 AM »
The 16v canister still has 3 ports, just one is on the bottom (hard to see) and the other 2 are on top.
The one that goes to the intake is the smaller of the 3
-goodyz
Offline 96Kicker
  • 1043
    • www.myspace.com
« Reply #4 on: November 30, 2007, 08:34:33 AM »
Thanks, yep no emissions where im at. I will look when I get off work today. I know exactly what solenoid your talking about. But some assurance wouldn't hurt. Ya my new harness is already installed and aftermarket 4x4 did it for me.
TJ
#801-554-3281
Offline 96Kicker
  • 1043
    • www.myspace.com
« Reply #5 on: November 30, 2007, 08:46:36 AM »
Almost forgot, what about the MAP sensor, I assume the vaccume hose for that plugs in on the back of the intake manifold,thats where I put it , it was the only vaccume port that was left on the intake manifold.
#801-554-3281
Offline mrfuelish
  • 2862
« Reply #6 on: November 30, 2007, 03:40:36 PM »
Mine has a maf sensor, what ya got going there? tbi?
Offline 96Kicker
  • 1043
    • www.myspace.com
« Reply #7 on: November 30, 2007, 05:06:12 PM »
Oops sorry MAF is what I meant. Im still new to the fuel injection club.
#801-554-3281
Offline mrfuelish
  • 2862
« Reply #8 on: November 30, 2007, 08:52:16 PM »
Can you post some pic's of what ya got going? use a pencil or your finger to point at what your talking about hooking up where?
Offline 96Kicker
  • 1043
    • www.myspace.com
« Reply #9 on: December 01, 2007, 06:49:32 AM »
Ill get some pics up Tonight.I am at work right now :(
#801-554-3281
Nine Pine
« Reply #10 on: December 01, 2007, 01:51:47 PM »
I am running a 1996 16 valve 1.6. The Mass Air Flow sensor does not require vacuum, or the hose obviously. This sensor is located in the duct work between the Air Filter box and the Intake Manifold. It requires three wires, 12 volt (supply), Signal voltage (between 0 and 5 volts when running), and a ground.
My motor does not have a Manifold Absolute Pressure sensor, it uses a Manifold Differential Pressure sensor. This sensor is located on the firewall on the passenger side (here in the U.S.A.) of the vehicle. It does require a vacuum source (a hose). The hose on mine is tapped into the hose supplying vacuum to the EGR solinoid valve(via a T connector), which is mounted on the rear of the valve cover. There is also a very small gasoline check valve in this hose.
Sincerely,
Nine Pine
« Reply #11 on: December 01, 2007, 02:46:58 PM »
IF you don't have inspections there, chuck that dead weight (charcol can)Not necessary, I just popped an inline fuel filter, like the ones you'd put on a lawnmower engine, onto the hose from the fuel tank. Just more crap to muck up the engine compartment
Offline 96Kicker
  • 1043
    • www.myspace.com
« Reply #12 on: December 02, 2007, 05:44:47 PM »
Ok in the first picture is the sensor on the back firewall,maybe the TPS and not maf or map?
sencond is the plastic t fitting on back of intake manifold, that the sensor is hooked up to(vacum hose)
third is the solenoid on front on intake, what hose goes here.
Thanks again
« Last Edit: December 02, 2007, 05:46:44 PM by fletcher »
#801-554-3281
Offline mrfuelish
  • 2862
« Reply #13 on: December 02, 2007, 07:06:27 PM »
Quote,My motor does not have a Manifold Absolute Pressure sensor, it uses a Manifold Differential Pressure sensor. This sensor is located on the firewall on the passenger side (here in the U.S.A.) of the vehicle. It does require a vacuum source (a hose). The hose on mine is tapped into the hose supplying vacuum to the EGR solinoid valve(via a T connector), which is mounted on the rear of the valve cover. There is also a very small gasoline check valve in this hose.
Sincerely,
Nine Pine
thats first pic.
the black solinoid goes to the canister on top to the small port.
Offline mrfuelish
  • 2862
« Reply #14 on: December 02, 2007, 07:13:12 PM »
also I just went out and checked the canister in my 94 and the bottom hose is missing so I'm guessing it is a drain just incase you fill the gas tank too much and over fill the charcol canister it just drains out the bottom. I have a 1994 and a 1995 and a 1996  16 valve so if ya need more just let me know which one to look at.
