T case gears!
  • 1544 Views
Offline Armour
  • 360
T case gears!
« on: December 10, 2008, 04:42:34 PM »
I am looking to put some t case gears in my trackick! Any recommendations on who's to use!
89 Sidekick. 33's.  Lincoln Locker,4.24 T Case, 5.13 gears. Warn M8000 winch.
96 Tracker. 39.5's Locked 44's front and rear, 6.5 t case, 4.10 gears.
Re: T case gears!
« Reply #1 on: December 10, 2008, 04:55:48 PM »
The only gears available for the TracKick is the 4:1 gear set.  Just give Low Range Off-Road a call and they can hook you up.
One thing to keep in mind is that the high range is NOT reduced like it is on the Samurai T-Case kits.  Only the low range.
Offline Armour
  • 360
Re: T case gears!
« Reply #2 on: December 11, 2008, 04:21:30 PM »
Sorry about the misunderstanding! I knew that the onlt gearset is 4:1 and that it onlt effects the low range! What i was refering to was, are there better manufactures then others! For example are Calmini better then Low range! Or all they basically the same!
Offline blacktrack99
  • 254
Re: T case gears!
« Reply #3 on: December 11, 2008, 04:32:16 PM »
Should be 4.24:1, but who's counting.  Go with Trail Tough. Fast, friendly, knowledgable service, and you'll save a couple hundred bucks, which goes a long way if you're having your favorite driveline shop do the install.
Offline okezuki
  • 51
Re: T case gears!
« Reply #4 on: December 12, 2008, 02:02:42 PM »
   Trail Tough x2. Abuddy and I put them in his kick with a twin stick in a day.
87,33`s,6-1 t-case,d.c.drive shafts,locked,m/l with cj`s,dt8000`s,& the will to BEAT THE SNOT OUT OF IT!
Re: T case gears!
« Reply #5 on: December 12, 2008, 05:51:01 PM »
Both TT and Low-Range have good reputations.
Your OTHER option is to do dual cases (sami behind kick), but that will instantly give you 40% reduction (kick hi-range = 1:1, samurai = 1.4:1) in hi range... so... unless you're planing on running some 35" tires, it may not be your thing.
Offline jason hutchison
  • 495
  • ZUKIWORLD Staff
    • ZUKIWORLD Online
Re: T case gears!
« Reply #6 on: December 14, 2008, 12:33:01 PM »
here is the installation article we have, just incase you haven't seen it.
http://www.zukiworld.com/month_010103/feature_calminirockcrawler_sidekick.htm
The installation is actually really straight forward. While you have the case apart I would install a twin stick if you can get one.. 37kicker had them but I haven't spoken to him in awhile and I am not sure if they are still available. I think if we bother evil twin enough they will have a DIY kit on the market before to long. I love my gears and I love my twin stick even more!
I have run both calmini and trailtough gears and I have been happy with both. Trailtough periodically has their gears on sale and they even may be right now for the holidays.
Hutch
