Poor Gas Mileage in my 1.6L8v Tracker
  • 18 Replies
  • 4604 Views
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
Re: Poor Gas Mileage in my 1.6L8v Tracker
« Reply #15 on: September 28, 2003, 12:48:23 AM »
OK is this some BS thing to see if
somebody will ask if you put on
32" tires or something ??
Just wondering
I WAS GONNA REPLY TO THIS AS HUH :-/??? BUT THEN I FIGURED IT OUT  ::)
Offline MEDEL514
  • 52
  • Ramstein, Germany
« Reply #16 on: September 28, 2003, 06:21:39 AM »
Well I found a MSD Blaster 2 coil last night and bought it for $35.  When I had it in, everything idled fine and sounded pretty much the same.  When I got it on the road, it seemed to have a better throddle response, but nothing to get exited over.  I took it to work today (9 miles each way) and didn't really notice any difference in the gas mileage.  I even filled up with mid-grade last night.  Maybe I should try a run with premium, but then I'd be making up for it by higher gas prices.
Problem still unresolved............
90' Tracker
- with some goodies
Offline MEDEL514
  • 52
  • Ramstein, Germany
« Reply #17 on: October 02, 2003, 01:06:55 PM »
Nobody has any other ideas?!?!?!?!
90' Tracker
- with some goodies
Offline Mikerpm4x4
  • 2875
  • 12
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #18 on: October 02, 2003, 02:21:03 PM »
Buy a new one!  :P
Have you taken it to a reputable shop for diagnosis?
We had a tracker with over 10 codes and poooor gas milage that nobody could figure out that we ended up taking to Suzuki. They had a notice that was only sent to dealers that said to replace a vacum line at the Map sensor because they would get a tiny crack that wouldnt be visible. It fixed it. This has nothing to do with yours because yours is a 8 valve but my point is in a situation like this the dealer might have an answer that most wont find. You can have then diagnos it and go home and fix it yourself if you want,
Mike
« Last Edit: October 02, 2003, 02:21:30 PM by Mikerpm4x4 »
