Did a second compression check on the Tracker today after finding out I had done the first one incorrectly. The good news is it's over 190 lbs on all 4. The bad news is , I managed to screw up the plug wires putting it back together, and when I went to start I got several LOUD backfires. Got out the manual, corrected the plug wires, and it starts, but misses on #3. It's getting spark, checked all the wires , plugs etc, all was good. Still missing, like it's not firing on one cylinder. Checked the timing and it was Advanced like 25 degrees! OK, I thought the belt jumped or somthing. Pulled everything apart, and the timing belt seems to be lined up fine. My FSM has me confused on a couple of issues, one being the the distributor timing. I wanted to check if the dizzy jumped time, or broke a gear, or somthing went out of wack, but I can't for the life of me figure out how to set it correctly. If the cam and timing belt marks are lined up, where should the dizzy be pointing? #1, #4? Any help on this would be really appreciated.
