I tinted mine using the Insta-Cling stuff from Wally World. Cut to fit, except leave about a 1/8" gap along the edges. (It will be invisible from the outside)  I used a *very* weak mix of soap and water (I think it was like 4-8 drops of soap to a pint of water). Spray the tint and the inside plastic after thoroughly cleaning the inside of the plastic. Apply the tint and adjust it, then squeegee out the water. Ignore any *really* small bubbles because they will disappear.  You must use the insta-cling (removable) type tint. I'll send pictures to you via e-mail of the results on mine.
