hcgalvin....a  question about gearing
  • 22 Replies
  • 3582 Views
Offline Evildead
  • 22
hcgalvin...
« Reply #15 on: December 07, 2005, 07:49:01 PM »
So hcgalvin, are you running a 4.16 sammy t-case or is it still stock??
What are your rpms at 100 km/hr (60 mph) with the 35's??
Oh and the link to the Gonzalo Bravo is here
http://http://www.pirate4x4.com/forum/showthread.php?t=176895
Offline hcgalvin
  • 1695
    • Granite Path
Re: hcgalvin....a question about gearing
« Reply #16 on: December 07, 2005, 10:18:11 PM »
I used to have 4:24's in the sidekick case. I took them out. I'm now stock in both cases.
Hmm.. I think I'm about 3800-4000 in 4th at 60. I can't use 5th too much, more like cruise control.
Check this link out:
http://www.granitepath.com/~kd7hcg/pictures/otherpics/mykick.xls
It's kind of old, it's how my kick was set up over a year ago, when I was still suzuki axles (albeit sas) and 33s. But you can change the numbers around and get changes. Don't mind the M90/T90 stuff around the edges.
Heather Galvin
Offline red_baron
  • 108
  • little red vit
    • surrey zuki society
« Reply #17 on: December 08, 2005, 12:46:33 AM »
i got a sammy t case fixed to back of my track t case and 4.88's in the toyota axles.
and with the 33's it runs spot on gearing wise.
3200 rpm at 60mph on the road.
Offline barcus
  • 97
  • fun
« Reply #18 on: December 08, 2005, 08:17:23 AM »
Your welcome Nate. I'm glad if i can help!
I found toyota R&P's ratio here http://www.off-road.com/toyota/projects/tacoma/intro-to-gearing/index.html
For stock sidekick/tracker now(without sammy t-case).
manual tranny:
5.83(clamini gears) X 27"(stock tire size) / 5.12(stock r&p's) =  30.74
Good for 30-31" tires.
Auto tranny:
5.12 X 27 / 4.62 = 29.922
Good for 29-30" tires
5.83 x 27 / 4.62 = 34.071
Good for 34 tires!
Fredo
hi fredo, isnt the manual tranny better for taller tires with its lower 1st gear ratio? (3.652 vs 2.826)
will a straight solid axle with 5.71s be ok for 34-35" tires on auto tranny (w/o sammy dual t-case)?
thanks
Offline Evildead
  • 22
Whew boy...
« Reply #19 on: December 08, 2005, 12:27:37 PM »
Allllrighty then....  so with my 4.16 t-case and the 4.10 axles , with the standard kick tranny and 33's, I should be abooooooot right....
I have another option as well... a toyota t-case from the same SAS pickup I am getting the axles from....!!!     Any ideas on RPMs??
(I havn't hit the gear link yet---this computer will not do it....grrrrrrrr)
Oh are the 4.88's aftermarket or did they come stock???   I thought all toyota SAS pickups (1980's) came with 4.10 diffs???
Offline mrfuelish
  • 2862
« Reply #20 on: December 08, 2005, 01:50:15 PM »
man if I had a toyota trans and t case I would get a ring r adapter and run dual xfers there are a couple of places making the dual adapters and you could run one of them in low range for the street, there was a couple of rigs that came with 4.30's for stock gearing but that would not be low enough for high range and too low for low range highway.
Offline red_baron
  • 108
  • little red vit
« Reply #21 on: December 08, 2005, 02:10:52 PM »
4.88 are stock over here in the UK on 80's trucks
Offline kozaz
  • 168
  • I love YaBB 1G - SP1!
« Reply #22 on: December 09, 2005, 09:47:15 AM »
4.10(toy gears) X 1.409(sammy case) = 5.776
27(stock kick tire) X 5.776 = 155.952
155.952 / 5.12(stock manual tranny kick gears) = 30.459
155.952 / 4.62(stock auto tranny kick gears) = 33.755
4.10 is Just enough gears for 30" tires with a manual tranny, and 33" with an auto tranny...well you will need lower R&P's.
Fredo
My math is terrible, how would I figure out the tire recommendations for the above setup, if I had 4.16:1 Rockcrawler Gear Set?
This kit provides a high range reduction of 12.2%.
And I assume the above reference "(sammy case)" means a Dual Transfer case configuration using a Kicker3 or something like Aftermarket4x4's "Kick Box" http://www.zukiworld.com/forum/index.php?topic=9492.0?
« Last Edit: December 09, 2005, 11:15:40 AM by kozaz »
