I read that, but it wasn't really clear on the final construction/assembly.
So in total, you cut up 3 shafts in order to make spacers.
On the Passenger side, you made a single spacer and used a drivers side CV Shaft.
On the Drivers Side, you made two spacers, welded them together, used the same CV Shaft.
But if we just wanted to use the stock shafts, you would need to have 4 spacers, two for each side right?
