I wouldn't put it in - not even in the summer
What's the factory spec ? I'm guessing 75W90 or similar - that 85W140 is going to be a lot heavier - try pouring it out of the bottle, you should be able to SEE the difference - 85W140 - the 85 before the W says it'll be no thicker than 85 in the cold and the 140 after the W says it's be no thinner than 140 in the heat. It's meant for a vehicle hauling a LOT more weight than you are.
