glasspack install cost?
  • 12 Replies
  • 12547 Views
Offline nuts4hotwheels
  • 169
  • Black Sunshine
« on: January 10, 2008, 10:33:26 AM »
What would be a good estimate for a shop to install a glasspack and 2" pipe from cat. ?
Black Sunshine
1998 4 dr Chevy Tracker 4x2 1.6L-16V
-K&N Performance Air Filter
-Thrush Glasspack -235/75-15 Pathfinder Trail A/P Tires  -Sony Xplod Cd Player -400W Visonik amplifier -2 10" Visonik Subwoofers *******************************
Offline jeff1997
  • 1228
  • 27
Re: glasspack install cost?
« Reply #1 on: January 10, 2008, 03:43:29 PM »
I got mine done with a 16" long x 3" stainless tip for $80.
3" Masterkit1 body lift
Custom strut spacers
  • 169
  • Black Sunshine
« Reply #2 on: January 10, 2008, 04:14:48 PM »
Thanks, that is a lot cheaper than I was figuring.
Black Sunshine
Offline museboy07
  • 641
« Reply #3 on: January 10, 2008, 05:53:00 PM »
at my shop to just put the glasspack in the original muffler location would be about 100
Offline jeff1997
  • 1228
  • 27
« Reply #4 on: January 11, 2008, 02:57:28 AM »
WOW!! It maybe wortgh the drive to IL for you!!  :laugh:
  • 169
  • Black Sunshine
« Reply #5 on: January 11, 2008, 04:12:41 AM »
Well, I was quoted $60 a while back to put it in with the stock tail pipe, but I wanted to go a little bigger after the muffler.  I didn't know how much it would cost to bend the tail pipe and everything.
Black Sunshine
thcrw739
« Reply #6 on: January 11, 2008, 11:17:15 AM »
Does adding a glass pack, running a strait pipe, etc, do anything besides change the sound?
  • 169
  • Black Sunshine
« Reply #7 on: January 11, 2008, 11:56:39 AM »
It increases power and improves mpg
Black Sunshine
thcrw739
« Reply #8 on: January 11, 2008, 12:26:21 PM »
I see,
Maybe i should look into somthing simple & cheap along these lines...
Offline whateverworks
  • 110
« Reply #9 on: January 11, 2008, 08:16:31 PM »
How does it increase power unless ya change the whole exhaust system from the catylitic converter all the way back? With the size of exhaust on a stock 'Kick it needs to be opened up all the way back to relieve the exhaust flow restriction to make more power. Or without adding a header for that matter... or without opening the intake air up with say an open element filter?
I took my cherry bomb off. It made the fuel mileage worse on my 16v and it sounded like a fart can honda. Annoying as hell and hides other noises yer rig may make. Barely even hear my stereo over that noise.
I would suggest a header, high flow cat back system and also an open element intake air cleaner. Look into another type of high flow mufler... But thats just my 2 cents.
Remember... the more air flowing in and the faster you can get it out will create more power... Not just a glass pack
Kelly
  • 169
  • Black Sunshine
« Reply #10 on: January 12, 2008, 03:30:45 AM »
So are you saying that reducing backpressure with a glasspack and 2" exhaust will not help performance? ???  I agree that a performance header would definitely help more significantly, but the decrease in backpressure will help, too.
Black Sunshine
  • 110
« Reply #11 on: January 12, 2008, 02:00:00 PM »
What I am saying is this... if there is any gain in power it would be barely noticeable fom just installing a glass pack cherry bomb muffler. I had one on my 4dr and it made nuthn but noise... Only reason why I did install it was I noticed the stock muffler was hitting the u-joint at the diff when fully flexed out. Only thing I noticed was I could not hear her cry for help and I got alot of headaches from noisy exhaust tone...
Kelly
  • 169
  • Black Sunshine
« Reply #12 on: February 17, 2008, 06:16:16 AM »
The glasspack is installed, now.  It cost $30 for the muffler and $25 for a local muffler shop to bend and weld a piece of pipe to compensate for the offset of the factory muffler.
I used clamps to install the muffler in case it wears and I need to replace it later or if I want a different muffler later.
It sounds great.  I love it.  The only drawback is, my wife loves the sound of it too and wants to drive it all of the time.   :laugh:  I love my wife!
If anybody needs info about the installation, just PM me and i will answer your questions or take more pics.
Black Sunshine
