ok the radiator on my 92 can the top be popped off and a new seal put on it is leaking from the uppper corner under the top
second I would like to do a home made steering stabilizer she jerks bretty good on shit T.O streets (summer/winter makes shifting and constant speed bumps)
I don't think it would be that difficult 2 brackets and the right size stabilizer
When I installed my 1.6, I took my '88 radiator to a radiator shop to get cleaned just to play it safe.
The shop owner said that I was lucky that I had an all-metal radiator as the ones with the plastic tops and bottoms were very hard to clean and tended to leak and/or fall apart if not done properly using the correct materials. The impression I got from this conversation was that the newer, plastic radiators were throwaway items as they cost more to fix correctly than to replace.
Suzuki changed it's radiator design around, I believe, 1989 from all-metal to plastic/metal.
A new front stabilizer will only mask other problems on your steering system. Unless you check and replace (if needed) the seals on the birfield joints -- they help dampen steering vibrations too, make sure that all linkage is tight (no play), make sure the the caster angle is correct and you have compensated for changes in the suspension (aftermarket draglink or Over-The-Top steering system) you will have steering control problems. Solid Axle Suspension (SAS) lifts can create "bumpsteer" where any moderate bump can cause the steering wheel to twist violently out of your hands.
To be safe, I did install a Rancho Steering damper after all the suspension mods on my truck.
Hope this helps!
