Gas tank lift.
  • 1148 Views
Offline MKOLSEN22
  • 217
  • Come on 32's
Gas tank lift.
« on: January 02, 2007, 11:41:42 PM »
I'm thinking of adding one of Sky's 2" body lifts to my tracker and I was wondering about lifting the gas tank at the same time.  I know that it has been done with the 3" body lifts but not sure about the 2" kits.  I was looking at the mounts the other night and it looks like the front mounts could be reworked fairly easy, but you might have to cut out the rear cross member and fabricate a new one to mount the fuel tank 2" up.
Any help?  Sugestions?  Comments?
Re: Gas tank lift.
« Reply #1 on: January 03, 2007, 01:23:47 AM »
see arcives mike hagen tank lift cheap easy ,and you keep the cross member.
Offline BigPig
  • 276
Re: Gas tank lift.
« Reply #2 on: January 03, 2007, 05:10:58 AM »
I did a home-made 2" lift and it looks to me like there isn't enough room to lift the tank the way Hagen did.  Maybe another way, but there isn't much room with only a 2" lift.
'89 Sidekick w/ 4.5" of lift.
Re: Gas tank lift.
« Reply #3 on: January 03, 2007, 07:15:41 AM »
I done the 3" body lift and the tank lift and it was getting very close on top of the tank. I dont think the 2" would be worth all the extra hassle.
Offline WorkInProgress91
  • 31 gets it done
Re: Gas tank lift.
« Reply #4 on: January 03, 2007, 08:36:55 AM »
i've also got the 2'' b/l, and lifted my tank by fabricating new front brackets, and driving a bolt through the rear crossmember for the rear tank mount.
91 sidekick
2'' B/L, 2'' coil spacers
31'' swampers
winch
custom bumper tank lift camouflage duct tape
Offline MKOLSEN22
  • 217
  • Come on 32's
Re: Gas tank lift.
« Reply #5 on: January 03, 2007, 11:13:29 AM »
Work do you have pictures of how you have the rear of the tank mounted with the bolt?  I would like to see that.
Thanks.
