Fuel Mileage
  • 24 Replies
  • 3373 Views
Re: Fuel Mileage
« Reply #15 on: December 07, 2008, 06:45:19 PM »
Tracker is your best bet for fuel mileage - upper 20's, samurai will be lower 20's. The cost of any engine swap will be way more than you'll see in fuel savings. It'll take many years to get the $$$ back from the swap. Diesel swaps are great - IF you're a rock crawler... and that's what you're doing the swap for. The days of cheap VW diesel swaps are long long gone.
And, for what it's worth - diesel doesn't have much HP, but HP doesn't mean squat in off-road. It's all about torque, and diesel has loads of it all across the RPM range.
Also consider the box style Isuzu Trooper if you want a cheap SUV with good gas mileage. I see a lot of Grand Cherokees for cheap now, but if memory serves, the MPG is bad.
Offline urbanwheeler
  • 696
Re: Fuel Mileage
« Reply #16 on: December 07, 2008, 07:06:24 PM »
I thought about buying an isuzu trooper once, but I found that the 4 cylinder (2.6 liter) has a head gasket and cracked head problem, and they only get somewhere around 17 mpg.
Offline Chris_B
  • 10
Re: Fuel Mileage
« Reply #17 on: December 08, 2008, 05:36:28 PM »
Seems the adapter kit is a little more for the diesel compared to the sidekick kit, the 1.6na diesel seems to go for a reasonable cost, about the same as a 16v sidekick engine. And I figure the diesel should get at least 50% better mileage. Not to mention diesels are simpler and last longer than gas engines. I figure i drive about 10000km per year, 23mpg is about 1 liter every 10km, so thats 1000 liters a year, at a dollar a liter I'd be saving at least 3-400 a year. And then I could run it on vegetable oil and save a little more on long trips. So I figure I should be able to make the extra money back in two or three years, after that its all gravy.
Judgeing by the sounds of things, it isn't much more difficult to swap in the diesel compared to swapping in a sidekick engine, I've even read its easier to swap the diesel into the samurai, than it is to swap the sidekick engine into it.
Re: Fuel Mileage
« Reply #18 on: December 08, 2008, 07:40:07 PM »
Chris B, your profile doesn't say where you're from, but since you're using the metric system I'll assume you're not in the US. If that's true, then diesel MIGHT be a better deal for you. I love diesel, but it's VERY expensive in the US, because diesel motors are rare here.
Offline Chris_B
  • 10
Re: Fuel Mileage
« Reply #19 on: December 08, 2008, 09:44:57 PM »
Ah yes, I live in Canada. I have always wondered why that is, why you guys don't like the diesel cars, it seems like a better engine in every way, a little louder but other than that.. The smart car is a perfect example, its been for sale here for a few years with a diesel, getting 65mpg, and its just now available in the US but with a gas engine that only get 45mpg or something like that. I just dont get it.
Re: Fuel Mileage
« Reply #20 on: December 08, 2008, 11:16:26 PM »
Probably for the same reason we won't adapt the metric system  ::)
Diesel is BY FAR a better choice for off-road. More low end torque, better MPG, more reliable...
Offline lowrider
  • 57
  • this is how the wife wants me to do it up
Re: Fuel Mileage
« Reply #21 on: December 09, 2008, 09:26:44 AM »
We don't either.I like desiel but can't afford the swap
Offline Chris_B
  • 10
Re: Fuel Mileage
« Reply #22 on: December 16, 2008, 05:59:38 PM »
Alright maybe you guys can asnwer me this. Would you expect to see an increase in mileage swaping the 1.3 for a 16v FI from a sidekick? Or is this just done for power? Just quickly looking on the internet it seems the sidekick is rated for around 22mpg, while the samurai is rated for 28 or so.
Offline idaholwb
  • 772
Re: Fuel Mileage
« Reply #23 on: December 18, 2008, 10:26:53 AM »
Diesels weren't very common here because Americans want the quicker throttle response of gas and then there is the emissions crap. If you are going to bother doing the diesel swap, try looking for the 1.6 turbo or 1.9 turbo. They shouldn't be much more than the non turbo versions and tons more power and mileage.
97 Sport
265/70-16s
2" lift
2.0 swap
Re: Fuel Mileage
« Reply #24 on: December 19, 2008, 10:14:51 AM »
Tough call.  I would think you would see a slight improvement in mileage due to the engine not having to work as hard and the fuel injection.  But you usually put larger tires on an such at the same time, and that reduces it.  :)
