Ok so I didn't get all the bugs out
(1.6 swap)
It runs and drives just fine but makes a rattle when around 3000-4000 rpm (will quiet down if you back off the throttle), in the drive way it will only make this noise for a second when you give the throttle a quick snap.
I've done the valve adjustments to the book, set the timing 10 degrees BTDC, the plugs are gapped to 28 thou and have a nice brown color to them?
Everything is new gaskets, seals, belts, hoses, plugs, wires, I did everything but mess with it's gusts and am now officially stumped
Somebody please tell me what I'm missing (begg'n)
Steve
