Sammi vs. Kick
  • 25 Replies
  • 4327 Views
Offline bashzuk
  • 784
  • Been zuked lately!!!
    • BashZuk's web page
Re: Sammi vs. Kick
« Reply #15 on: June 06, 2005, 01:54:57 PM »
Hey, thanks all... great advice so far, I am 5'11 155lbs. so I should probably really sit in the drivers seat to really see if I am comfortable. I like the idea that they are cheaper to lift, and overall I think they look cooler, (no offence to sidekicks) and they have solid axles which is a bonus I'd say.
Make sure if you sit in a sammy it has different seats than stock the stock seats suck. I put Neon seats in mine and to date has been the best improvement for me.
5'9" 265  with a 52" inch chest. So I'm not a small boy by any means.
But there are more track/kicks to pick from since they only imported about 20,000 Samurai's
« Last Edit: June 06, 2005, 01:56:12 PM by bashzuk »
Mean Green Wheeling Machine
Offline rkteckt
  • 214
  • I love YaBB 1G - SP1!
Re: Sammi vs. Kick
« Reply #16 on: June 06, 2005, 04:02:29 PM »
For me it was a simple choice......
There are NO LIFTED MODDED SAMURAI's in Northern Kentucky.......
SO I had to have one.
this is my third sammy over the last 15 years and i wouldnt sell it unless i had a line on a 1995 cherry sammy that i could build from the ground up.  THere was one on Ebay, but it was in philly and sold for too much to make it worth investing another 3-4 grand in a lift and engine swap etc.....
I have nothing against trackers, i see a ton of them all over the place with their cute little foam graphix and hub caps.....:-)
1991 samurai , Mall Crawler, neon green, YJ lift, Wifes vanity plates.
1988.5 tintop too many mods to list. The work samurai.
2005 Avalanche Z71
2003 Matrix XRS
1993 sidekick 4dr 2wd donor thats too nice to destroy yet. 1992 Toyo Pup POS
Offline flexmonger
  • 209
  • live to wheel and wheel to die.
Re: Sammi vs. Kick
« Reply #17 on: June 06, 2005, 05:50:01 PM »
  Build a sammy, more parts, more help and are more up to wheeling than a kick. You take the same amount of money for wheeling mods for a kick and use them for a zuk instead, and you would have a way more capable sammy.
Offline Memphis
  • 107
  • Need a Rig
Re: Sammi vs. Kick
« Reply #18 on: June 06, 2005, 11:08:00 PM »
rkteckt that is one NICE samurai! I really like that one, what size tires are you running on that machine? Do you use that as a DD?
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
Re: Sammi vs. Kick
« Reply #19 on: June 06, 2005, 11:09:37 PM »
well, before i bought my vit, i looked at about 10 or 15 sierras, within a price range. i had my mind set in getting a sierra, and thats what i was looking for. but hardly any of them appealed to me.
then, the very first vitara i looked at, i bought. it just felt right, even though the vits condition was worse than some of the sierras i looked at.
anyway, go with what feels right. look at it, drive it, look at it, and go with the flow.
with tech now, the sierra is the way to go if you want a real bad a$$ trail rig, as mods are easy to do. SPOA, RUF, SR, Yota Diffs etc etc etc. easy peasy. theres a lot of support for the sierra. ride quality is what you make it, and cab size is little to be desired.
with a vit, parts are less readily available, more fabrication work for custom parts and installs etc etc. spacious interior lets you stretch out, and not feel so confined. ride quality starts off good from factory, and as things are, can always get better from there on.
i havent regretted a single minute i've had with my vit.
good luck, and heres a couple of pics.
« Last Edit: June 06, 2005, 11:13:21 PM by sikid_01 »
Re: Sammi vs. Kick
« Reply #20 on: June 07, 2005, 03:16:47 AM »
That's a myth spread by the jeepers.  They're there!  But yours is a fine representative!
« Last Edit: June 07, 2005, 03:17:08 AM by LilRed »
Offline Bama_Zuk
  • 17
  • No it's not a baby jeep
Re: Sammi vs. Kick
« Reply #21 on: June 07, 2005, 06:03:20 AM »
In my mind sami is the only way to go if you wont it for offroading only you just cant kill the damn things. their as thouh as your grandmas hamburgersteak when ya was a kid.
Offline Suzuki1.8
  • 283
Re: Sammi vs. Kick
« Reply #22 on: June 07, 2005, 03:37:24 PM »
Man were all argueing what zuk is better. The fact is there are zuks and thats what makes them great. I have had sammis and kicks. i even have a xl7 the main point is i love all of them. They are great off road machines no matter which one you own and they have a own little culture to them. I guess you have to own one to know.  But i have yet to see a zuk a i didn't want to take home with me.
Offline rkteckt
  • 214
Re: Sammi vs. Kick
« Reply #23 on: June 07, 2005, 05:04:53 PM »
Yes my Sammy is a Daily Driver.....in fact i use it to run business errands to save gas and wear on my avalanche.
I have hauled bags of cement, tools, even a door that needed glass repaired. Even Better I can drive right up to the side of the buildings im working on or delivering too, no matter how steep the yard is.
Im planning to do a 1.6 16v swap and to replace the cheap SPOA with a Calmini 5.5 shackle reverse lift.....which will hopefully give me back expressway speed and handling.
The tires measure 30 inches in diameter, but there is no indication on them what size they are.
I am sure there must be other lifted Sammys near me, but in 17 years of looking i have never seen one.
on a side note, if you want to use your sammy for a light duty work truck (very light duty) you can get a front and rear hitch mount bumper set, and then add cargo bed extenders from Do-It-Best to both front and rear, it will let you carry ladders and lumber on top from time to time.
There is also a hitch mounted snow plow called a snow sport that can turn your sammy into an inexpensive driveway plow.
Bye bye.
2005 Avalanche Z71
2003 Matrix XRS
Offline bashzuk
  • 784
Re: Sammi vs. Kick
« Reply #24 on: June 07, 2005, 05:32:07 PM »
The fact that I want to bring home more zuk's is causing an issue with the I don't want that many cars in the driveway argument.
Re: Sammi vs. Kick
« Reply #25 on: June 07, 2005, 06:00:55 PM »
backyard. FrontYard, SideYard.
Lots of yard space ;D
