Cast valve cover questions
  • 2058 Views
Offline 144man
  • 85
« on: March 05, 2016, 08:18:21 AM »
So I got the cast valve cover off eBay, and it looks like a direct swap, but there are two hose connections, and my stock '87 Sammy has but one.  Which one do I hook up and which one do I plug?  Does it matter?
Offline 144man
  • 85
Re: Cast valve cover questions
« Reply #1 on: March 10, 2016, 04:07:59 PM »
Please guys, a little help?  Two pipes, one hose.  Does it matter?
« Reply #2 on: March 10, 2016, 04:28:22 PM »
It probably doesn't - especially if you're running a carb.
I'm not certain if that cast cover was ever fitted to the Samurai, it most likely came off of a Swift, which was fuel injected - the crankcase ventilation systems on fuel injected engines have two hoses, one to the inlet, and the other to the PCV system - they do it this way so all the air through the engine is metered.
It'll probably be easier to plug the one near the end with a rubber grommet.
