Try adjusting it. If there is no free play in the pedal then the clutch might not be engaging the flywheel fully. If that doesn't work, you probably need to do the clutch. But hey, the transmission is small and light, Samurais/Trackers are tall enough to get under easily, and clutches are pretty easy to do(especially with a shop manual)!
