Weld the spidergears up while the 3rd members are out too!
I would caution against this, Welded spider gears have a habit of breaking when you need them most. When they break they take out the whole axle, not just one wheel. You will then be faced with the prospect of trying to limp home on just one axle or on the tow strap. A spool only costs about 100.00 Trail Tough sells them. Do it right the first time and you will not be sorry later. I am speaking from experience here.
Oh and don't spool the front or you will not be able to steer in 4WD. The lock-right works fine though. Again speaking from experience
Honestly I dunno how worse a mini-spool up front would be versus a lockrite. I could count on one hand the number of times I've heard it ratchet (and it was setup by brent at trailtough too).
