If you have a SPOA (~5" lift), I would get the 1" longer slip yoke for the rear driveshaft.
For the rear driveshaft in a SPOA application, I run a shortened front Samurai shaft; better u-joint angles, less vibes than the stock shaft + spacer. A local machinist has done several for me and he only charges $40-$50 each. (He didn't think that welding on the slip-yoke was a good idea as it is a forged piece. Hence, we went with a shortened front shaft.)
