extended rear brake lines?
  • 10 Replies
  • 1951 Views
Offline Chief
  • 678
  • Whaddya lookin at??
« on: January 26, 2005, 11:45:49 AM »
Anyone make extended rear lines for trackers? And also, how do they connect together? Can I connect them end to end, or not? Thanks!
Re: extended rear brake lines?
« Reply #1 on: January 26, 2005, 12:24:08 PM »
I know Calmini has them
I don't know if they'll sell ya one with out the whole kit ;) ;D
Offline DaddyDave
  • 204
  • Indeed
« Reply #2 on: January 26, 2005, 02:59:53 PM »
"The maximum effective range of an excuse is 0.0 meters."
Offline Chief
  • 678
« Reply #3 on: January 26, 2005, 08:37:11 PM »
rears are the same: http://www.puresuzuki.com/brake_lines.htm
Cool, thanks!
Offline Natebert
  • 1098
« Reply #4 on: January 27, 2005, 02:39:09 AM »
A visit to my local VW bug parts house is all that is required.
I got an 11 inch extension for $8 bucks.  (it bolts inline with your existing line)
I'ts an old VW bus brake line that just bolts right in.
I'll see if I can get a part number.
~Nate
« Last Edit: January 27, 2005, 02:42:16 AM by natebert »
Offline Chief
  • 678
« Reply #5 on: January 27, 2005, 02:58:16 AM »
~Nate
Excellent!!
Offline Natebert
  • 1098
« Reply #6 on: January 27, 2005, 12:07:47 PM »
Here are all of the part numbers on the label.
It was a Meyle (Germany) number 100 611 0045
as per VW 211 611 775 C
Also on the tag is HB 15310 (220031069  [I think this is the local shop part number]
~Nate
Offline mesjr2004
  • 422
« Reply #7 on: January 27, 2005, 01:15:28 PM »
you can also get them at oriles,you will have to have your brakeline with you just tell them you need a longer one of these
Offline Chief
  • 678
« Reply #8 on: January 27, 2005, 08:44:33 PM »
Thanks a bunch guys!!!
Offline Chief
  • 678
« Reply #9 on: January 28, 2005, 02:00:22 PM »
Hey, is this it???
Brake Line Flex Hose-F .  211-611-701N  Bug  65-66  $11.99
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #10 on: January 28, 2005, 03:25:34 PM »
Hey, is this it???
Looks really close,
I'm not sure what the difference between a 701 and the 775 is. Can you get a closer pic?
female on one side and male on the other?
Heather Galvin
