gears
  • 1505 Views
Luke
gears
« on: September 20, 2007, 05:21:17 AM »
will gears from a tracker/sidekick front end fit in a samurai?
Offline john1974
  • 617
  • http://zuknation.net
    • Zuknation
Re: gears
« Reply #1 on: September 20, 2007, 08:20:14 AM »
I assume your talking about the diff gears.  Yes but only 2 front ring and pinion from a tracker/sidekick will bolt into the samurai.  May I add its a very good mod for sammy I have done it on my 87 I sold off.
Offline mrfuelish
  • 2862
Re: gears
« Reply #2 on: September 20, 2007, 10:20:22 AM »
yep, 1995 or older for the front splines to match(22) and say 1996 and newer for the rear splines to match(26)drill the flang holes on the rear four times (could be smaller or larger pattern needed) and there ya go.
PhnxCaller
Re: gears
« Reply #3 on: September 21, 2007, 07:41:18 PM »
What are the benefits? Are they beefier or/and is it a different ratio than the sami's? Really curious!
Luke
Re: gears
« Reply #4 on: September 21, 2007, 07:45:37 PM »
I hope I didn't screw up, I haven't been able to access this site for two days now so I went ahead and bid on these. They are 4.62 ring & pinion gears from a sidekick/tracker front.
        So your saying I have to drill the diff. holes out for the ring gear???? I also read somewhere that I will need spacers for the ring gear?? ???
Luke
Re: gears
« Reply #5 on: September 21, 2007, 07:49:05 PM »
        Yea my 87 has bigger tires so I neeed to regear
Offline mrfuelish
  • 2862
Re: gears
« Reply #6 on: September 21, 2007, 11:04:26 PM »
The bolts are for your drive shaft to bolt up, the stock tracker fronts have aluminum housings that are weaker but you can put the gears in the sammie's housings, sammie=3.73 gears tracker 4.3 to 5.83 ratio  I have 4.3 for one and 4.88's for another and a set of 5.12's for just incase  ;D
