I have been thinking about it,
but there was much to buy (equipment)
now that it looks like Zukizzy and I will be
working on parts and mods, it's much
closer to being a reality.
This is a simple swap part, I could whip up
a custom set no problem, I'm looking at the
sourcing of parts, and Zukizzy has many sources.
I want to be able to have replacements be on
the shelf, same with parts, this is a part that
lets say the inner CV blows out and you have to
do a trail repair, well you would unbolt the inner
CV 3 bolt flange, collapse the slip spline, get the
broken end clear to pull it out, pop it apart, and
slide a new inner CV and spline onto the slip shaft,
bolt back up to the flange and go.
The outer will be a little harder because you have
to take the hub off, but the procedure is the same
Trail fixes are not hard now, but these would be
even easier, and best part, no inner CV cup, these
would be replaced with a more durable CV that has
no cup, which is the most common failure, so these
CV shafts will be more reliable
